My replacement stopped all together after I shut it down because I was ill. I tried charging it but it's not responding.
SOURCE: Charging Adapter
i think your laptop needs 90watt adapter because of that its not charging.....
SOURCE: Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
SOURCE: acer 4200 notebook unresponsive keyboard
Hold down the function key Fn and tap the F7 key,
now try the touchpad
SOURCE: Electrical system shut down like battery was not
I would check my wiring harness for faulty connections and possibly burnt wires. Also trace the wires from your alternator to the battery. check them over. The battery may need to be replaced. If you let it run down alot and kept jumping it.
SOURCE: My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
