SOURCE: my denon amplifer was playing okay then the trebel
Determine if it is both left and right channels. If it is then you are looking for something that is common to both channels as the cause. It could be something to do with the tone circuit, perhaps an IC, another suspect is the bias section. And if only in one channel then at least you have something to compare it when seeking the fault.
SOURCE: Denon PMA-520 amplifier clicking noise
Sounds to me like a bad capacitor, but not sure. I would look inside for any slightly bulging capacitors or capacitors whose plastic wrappings have melted or shrunk or cracked (most caps are cylindrical). Please unplug first and be careful inside there and do not touch anything. I actually came across your post while looking for info on what I think is the same amp my brothers had but blew, and I was going to ask if they still had it so I could repair it. I've been very successful at repairing my electronic equipment such as Altec Lansing Model 95 speaker crossovers, power supply in Emu Emax II, and almost everything else in my studio.
SOURCE: Operating Instructions, Denon PMA-535R/PMA-735R
Hi there
You can download one from here Select the FREE download button and you will get a PDF copy of the manual. Let me know if you have any problems getting it. Cheers
regards
robotek
SOURCE: Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
