SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
SOURCE: how much salt for 7000gal or 18x52 intex steel
To start up you'll need 175 pounds (80 kgs) When the Low Salt light comes on, add 45 pounds (20kgs)
SOURCE: missing skimmer manual
You can get a downloadable manual here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
SOURCE: I have an Intex Ellipse 24x12 pool. I just got an
MAKE SURE YOUR SUCTION HOSE IS GOING TO THE PUMP INLET ON THE FRONT SIDE OF THE MOTOR ON THE PUMP. YOUR DISCHARGE SIDE WILL BE ON THE BOTTOM OF THE FILTER SIDE OF THE PUMP. IT SOUNDDS AS SIMPLE AS YOU MIGHT HAVE THE HOSES REVERSED.
