SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
SOURCE: Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
SOURCE: WATER RUNS COLD
ITsounds like you still have air in your lines try bleeding lines out some times it takes a while .or your getting air in lines some where try looking at the boiler at fittings .
SOURCE: mixer shower connected to combi boiler running hot and cold
Mixing valves usually have a diaphragm inside that keeps the hot and cold separate. If the diaphragm is old it may be allowing the hot and cold to mix improperly at the back of the valve. This is similar to a cross connection (a hot water line tied into a cold line) in your plumbing. Cross connections interfere with the performance of Combination Boilers and Tankless Water heaters due to their having no water storage or a very small buffer tank. The brand of the valve will help as each one is different in their mechanical design. If this is the problem you or a licensed plumber can replace the cartridge in the valve. Refer to your valve's owner's manual for part numbers.
