Kenmore front load washer model 110 49972 602
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
SOURCE: Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
