SOURCE: micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me [email protected] or [email protected]
SOURCE: Where do you put the Micro SD card in a Motorola V3 Phone.
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
SOURCE: Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
SOURCE: Micro sd card in ke850
When the Prada 1 (KE850) was launched, it officially only supported up to 8 GB SD(HC) cards, but there are SD card manufacturers (i.e. Kingston) which claim that their 16 GB cards work in a KE850.
You could contact LG Customercare to confirm this or go with the 8 GB card to be sure ...
SOURCE: Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
