Question about Panasonic DVD-LS50 Portable DVD Player
Error code on Panasonic LS50 portable DVD player
I'm getting an error coded on my Panasonic portable DVD plaere, model LS50. The screen says "reading" but the dvd is not spinning , the an error code H03 shows up.
Well worth the $9.95 if you can fix the problem.
Thanks.
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Posted on Dec 12, 2007
  • 3 Answers
As Tair_tazz said, the problem is solved by puting the laser reader again in the middle of his ride way, off course removing all the screws from the back cover. Thanks body!!
Posted on Sep 20, 2009
I also had the HO3 code...I re-alligned the laser..and now it reads the disk and shows the movie....BUT NOW I have no sound..?
I re-initialized the unit & still now sound...? IDEAS anyone..?
Posted on Jan 03, 2008
Unlock region code
How do I unlock region for a region b Samsung bd d5100 blu ray player so I can play all regions
Jan 01, 2014 | Panasonic DVD-LS50 Portable DVD Player
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
CODE: HO2
i think the problem is an accumulation of dust. try cleaning it out with a can of compressed air, or if you dont have that, by blowing on the lens gently.
Aug 20, 2008 | Panasonic DVD-LS50 Portable DVD Player
Panasonic portable dvd player - error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Apr 05, 2008 | Panasonic DVD-LS50 Portable DVD Player
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
DVD-LS5 portable
The spindle motor is defective.
Mar 21, 2008 | Panasonic DVD-LS50 Portable DVD Player
Panasonic Portable DVD Player LS50
Can you see or hear that the disk is spinning up normally as it did before? I understand that the small, spin-motors on these portables often go bad.
Jun 06, 2007 | Panasonic DVD-LS50 Portable DVD Player
DVD-LS5
had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
it helped plenty of friends hope it helps you
Feb 20, 2007 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-LS50 Portable DVD Player Logo
603 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
