Question about Linksys Wireless-G WRT54G Router
I would like to know how to passord protect the wirless router
    Sergeant:
  • 168 Answers
Login to the router. The default is 192.168.1.1 . Enter the current username and password. If it was never changed, the username is blank and the password is 'admin' without the quotes. Choose the administration tab and the first item on that page is the password. Enter your new password and reenter it on the second line. At the bottom of the page, click on save settings. Several seconds later, a screen will tell you that your settings have been saved. Close the tab or window to the browser unless you wish to make more changes.
That's it.
Posted on Aug 01, 2009
  • 742 Answers
Go to http://192.168.1.1 to access your router's web interface. From there, you will see options to "encrypt" your wireless network.
I have a acer laptop the keeps turning off wirless connection
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 20, 2012 | Computers & Internet
I have dilik dir 615 but i dont know passord to use wi fi for my i phone
Login to the router wireless section (using a LAN cable and change the password.
Dec 06, 2010 | D-Link DIR-615 Wireless Router
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
I do not know how to secure my wirless network
Go to this link for a tutorial on how to secure your wireless :
http://cache-www.belkin.com/support/dl/securing_your_wireless_network.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 02, 2009 | Belkin Computers & Internet
I want to connect another pc I have the internet on my primary pc but need to know how to add the other
If it is wirless it is quite simple just lock for your wirless conection on the botom right corner of scren. Now you will need to right click on it and say view wirless networks. It then will pop up a list of available networks that are in range of your computer. Slect the one you own. It may ask for a WEP password which is located on the botom of rour router. I hope this helps and lock forward on helping you fix any other problems you may have with your router.
Jan 04, 2009 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Jan 03, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How to install d-link on mac
Well if it is protected by WEP password you will need to enter $ first and then the password. But befor you do that up at the top on the right side there should be an icond with wirless signal clcik on it and slect your wirless network then enter the password if it is protected.
Jan 01, 2009 | Linksys WRT54G (0745883555482) Router
Wirless router
Try This link:
http://www.retrevo.com/support/Netgear-WGT624-Wireless-Routers-manual/id/420dj078/t/2/
Oct 11, 2008 | NetGear WGT624 Wireless Router
Psp connection
the wep key is ur pass word that u made to protect ur wirless signal from hackers. u need to know the passsward.
Jan 14, 2008 | Belkin High-Speed Mode Wireless G Router 4...
Linksys Wireless-G WRT54G Router Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
