Cannot get creatacard to show address book
When I try to access my CreataCard 3 the following comes up: Microsoft Visual C++ Runtime LibraryRuntime Error!Program: CProgram FilesCreataCardPlus mnot32.exeabnormal program terminationhope you can help..Thanks, Sam
  • 86 Answers
SOURCE: program
I wrote this as a vbscript. It's Visual Basic code in windows script. If you have XP, just copy the text into notepad and save it as "vowel.vbs". Now double click the newly created script file.
' vowel.vbs
' This VBScript is used to count the vowels and consonants in a string.
' Designed and Tested on Windows XP Pro SP2
' Version 1.0.0 - 02.20.2008
' This code may be freely distributed or modified.
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
for i = 1 to len(str)
select case mid(str,i,1)
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
consonants = consonants + 1
end select
next
msgbox "Vowels = " & vowels
msgbox "Consonants = " & consonants
'End of script.
Posted on Feb 21, 2008
mcc99
  • 51 Answers
SOURCE: problem about our thesis
I am not sure I understand the question. You are trying to write a VB program as part of a school thesis assignment that will be usable as a book-management system? Or are you asking what are good books to get to learn to write VB programs? And what Vb are you using, "classic" VB or VN.NET?
Posted on Mar 07, 2008
Ryan5443
  • 336 Answers
SOURCE: Product Key Number Microsoft Office Home and Student 2007
First you need to go to the webpage below and download this software. Next you need to copy it into the installation directiory and run it. It will allow you accsess to the software, useing my Office 07 Key. If you have any questions tell emand I can help you.
RCF
http://www.4shared.com/file/61012956/3d4e0b82/MS-Office07GenuinePatchbyteamBlack_X.html
Posted on Aug 31, 2008
  • 159 Answers
SOURCE: i have a form in
It may be tough to get help because this message is posted in an inappropriate forum. But let's try ...
Which one restarts, the host or the client? Is there an error message or anything? Which version of Access? Which operating systems on which computers?
Before you do much, you may wish to make sure you have all the updates installed. Point Internet Explorer to http://update.microsoft.com and check in the left-side menu to ensure it's checking for updates for all things, not just windows, then check.
After that, go to http://officeupdate.microsoft.com and run the scan there.
On the other computer, please google "access runtime MYYEAR" to ensure you're using the latest version, and then run officeupdate.microsoft.com on that computer as well.
Posted on Dec 15, 2008
SOURCE: error occured during microsoft visual studio 2005 installation
installation wizard closes during loading the installation components in an AMD Athlon(tm) 64 bit(single core) system
Posted on Mar 10, 2009
Creatacard Plus won't open address book or calendar?
no computer stated
zero inputs.
sounds like you lost the book on what ever HP device that is.
right?
i went to hp.com
searched
got ZERO hits
why?
goggle 1st hit ( shows not HP at all)
i have american greetings, creatcard plus version 1.01, 1995.
Apr 24, 2016 | HP Computers & Internet
I have windows XP and Creatacard 3 has run well for several years now and all of a sudden, it tells me that the address book is not loaded... how do I load it? I have unstall and reinstalled and over and...
Software issue. You need to do a complete uninstall of the program by going into the registry after you uninstall to remove any and all fragments left over by the normal uninstall. THEN, reinstall the program and see what happens.
Aug 31, 2017 | Broderbund American Greeting CreataCard...
American Greetings Creatacard Silver 5.0 will not install in vista or windows 7
Easiest way to try to solve that is to do the following. 1. Go to My Computer and find the cd/dvd drive with the install disk in it. 2. Right click and select explore. 3. Find the installation file 4. Right Click and select properties. 5. Select the compatability tab. 6. Under Compatibility mode check the check box for "Run this program in compatibility mode for" 7. In the drop down menu select windows 98
Select the settings and visual theme settings to match the program specs. You may need to repeat this process after the install to allow windows to open the program. Follow the same steps but look for the program file under c:\ program files.
Jan 12, 2010 | Broderbund American Greetings Creatacard...
I am getting a laptop computer. I have CreataCard Platinum 8
Vista has been a problem since it was introduced. Essentially Microsoft released it without ensureing driver were available for existing software and hardware. Some manufacturers have been making efforts to get Vista compatible Drivers available. Check the software websites for updated drivers.
Feb 20, 2009 | Broderbund American Greetings Creatacard...
Creatacard gold 3 won't work with Vista
I just installed Hallmark Comedy Card Studio by Sierra on my Vista 64-bit machine. It works with all the saved files from Creata Card. If the Calendar and Address Book data file is fmnot32.dat, rename it to planr32.dat and then the Event Calendar will work as well.
May 30, 2008 | Broderbund American Greetings Creatacard...
Creatacard 3
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Apr 23, 2008 | Broderbund American Greeting CreataCard...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
