Question about Whirlpool Duet GHW9150P Front Load Washer
Duet error code F 02.
The error code states we may have a clogged drain line. I have cleared obviously clogged drain line from washer to drain pipe, cleared clogged black rubber boot attached to bottome of barrel, made sure large filter was clear and same error code comes up.
Do I have to clear the error code somehow?
Thanks in advance..........Ed, Davenport, Iowa
  • 9 more comments
  • danzima Jan 22, 2008
    Cool-took only a couple minutes...mostly trying to find the little TORX screw bit for my powerdrill... Filter clogged, and there was even a small nail which luckily never made it to the impellor! THANKS,that was easy...just a little messy since I omitted the bucket...
  • Anonymous Feb 12, 2008
    It did not take long to learn that my motor pump had been damaged...the same error code and poor drainage indicated the pump was shot. I placed an order for a new pump online...the hard part is living without for a few days! It was then attached and has been running like new. Maybe your motor pump is shot,also...
  • Anonymous Apr 21, 2008
    Same problem, I just take off front panel and remove the filter housing. Clean and re-installed, Quick fix. Thanks for the info.
  • arbco Sep 08, 2008
    cleaned the drain line and still have F02 coming up.
  • kathy_2004_6 Sep 08, 2008
    havin problems even washing a load of clothes doesnt do it especially whites what is the deal it never runs the whole way threw
  • Anonymous Sep 09, 2008
    The solution of removing the front panel aand cleaning the screen fixed my problem. There was a sock in it. It ws easy and took less than half an hour..Once again Dad is the hero of the day.Don't forget towels or a pan. There's not a lot of water ther, but a little goes a long way..
    Thanks for a great web site..
    Mike
  • bnelle Sep 09, 2008
    washer is displaying 02 F and won,t complete the cycle
  • Boyart Dec 05, 2008
    I have the same code F 02. I checked/cleaned drain, filter every looks fine. I was also able to see the water drain from the machine. It looks like that the spin cycle won't come on. I put the machine on Drain / Spin and it doesn't spin. I think the F 02 is telling me that there maybe a problem with the spin cycle instead of the drain. Any suggestion?
  • Anonymous Jan 11, 2009
    Washer is draining but it wont enter into spin
  • Anonymous Mar 31, 2014
    The drain pipe is blocked resulting in water remaining in the washer. I unscrewed the filter and drained the water there. But further down the drainpipe, still clogged. How can I access that
Just had this problem. Remove the kick plate in front of machine. The drain pump filter maybe clogged. Turn the white screw to remove filter, but be sure to have towels or a bucket handy. I clean mine out and now is working fine.
Posted on Dec 11, 2007
Same problem--washer would not drain--F02 code. Tried drain and rinse per trouble shooting guide with no luck. Door would not open. Unplugged power cord and then was able to open door. Removed front cover per earlier response (3 torx-head screws at bottom of front kick plate). The filter is in the bottom center--remove the front screws and the filter can be moved forward to be drained (a 13"x9" baking pan worked great). You can pull the motor and filter forward and unscrew the filter to let the water drain without flooding the floor. Our filter was clean, but the clog was a rubber mass within the flexible element between the filter and the bottom tank of the washer. The rubber had to be crumbled by squeezing the flexible element and using a soft snake in the line. As a note, there is a ball float at the bottom of the tank that should not be confused as a blockage and crushed. The tank was flushed with small buckets of water to remove the rubber particles. This problem was caused by washing an old rubber-backed rug in hot water--don't do this--cold water wash only!!! The rubber came off and formed solid balls of rubber which plugged the drain.
Posted on Dec 13, 2007
Error code in book is wrong,,try changing the pressure switch
Posted on Dec 06, 2007
  • Priscilla Feb 21, 2013
    Your exactly right. The error code is not fair clogged drain always. If your machine is draining properly then the problem is the pressure switch.
    Its not wrong in the book but your right that it is not always the problem. If your machine is draining properly then yes it is the pressure switch.
Go with JERZEEGIRL's suggestion 1st. unscrew the white filter top and more than likely the issues with be there. We had a washcloth stuck in ours. just saved ourselves 100 bucks!
thanks everyone.
Posted on Feb 12, 2008
The solution of taking off the front pannel and draining and cleaning the discharge area to the pump...WORKS!!!
We had a half dozen q-tips, a twist tie and a ton of hair! Be ready for a ton of water draining as you open the discharge cap.
Posted on Dec 13, 2009
  • 9 Answers
Thanks for the info. Unclogged mine by following Jeezegirl's solution of taking off front panel and unscrewing white plug. I needed a big pot to catch the water. I should have pulled the white plug (screw top and all) out from the washer first, then I would not have had to mop up water afterwards.
Posted on Apr 24, 2009
Thanks for the info! One quick trip to Ace for the ratchette set, and I was good to go!!! Worked like a charm....
Posted on Dec 03, 2008
I did what jerzeegirl said and my machine is working great, thank you so much. Best part is saving the money to have someone come out!!!
h in Ct.
Posted on Oct 29, 2008
  • 447 Answers
Try unplugging it wait a few mins and the power up. Its the only way to reset them. I am assuming that the machine does pump the water out fine. If the drain is still clogged, or the pump impeller jammed, or if the pump is bad it will still not sense that it is draining normally.
Posted on Nov 25, 2007
What does code f03 mean
An F03 error code on many front load washers indicates a failure to drain properly. You can usually clear this fault code by pressing the pause/cancel button. Next, check the drum for water. If the drum still has water in it, restart a drain and spin cycle. This should drain the water from the tub.
If your washer will not drain, check the drain hose for kinks or clogs. Make sure that the drain hose is not stuck more than 8 inches down the stand pipe.
If you do not hear your drain pump running, you may have a problem with your control or your drain pump. Also, if your pump is making a loud noise, it may be clogged. These problems would require service by a technician.
May 19, 2015 | Washing Machines
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Have a Maytag washer MAH8700AWW, I keep getting ND messag. Replaced water pump and machine still behave the same.
Hello, You may have not have had to replace the pump in all actuality. The ND error code can be caused by anything caught in the entire drain area which means from the port hole that comes out of the outter tub you would need to remove the hose that connects to this spot and then to the pump. Also you would remove the drain line after the pump as well and assure in both areas that there are no obstructions. If you still have the ND error code after you have assured you have no blockage in either of the above mentioned areas message me back for further diagnosis. Also after you clear the clogged area make sure you unplug the unit for 7-10 minutes this causes the control to reset which is easier then you haveing to go into diagnositic and clear the error code. I await your reply Thanks Rick
Aug 27, 2011 | Maytag MAH8700A Front Load Washer
F21 code
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working.
If you need more help, check other tips in THIS LINK.
Hope helps (remember to rate and comment this answer).
Jul 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I keep getting an F 02 error on my washer. what do I need to do?
Hi,“F02” is a Long Drain error.If the drain time exceeds 8 minutes this error code will be displayed.In addition, a “SUDS” error may also be generated as a secondary error.This is an indication of a drain pump problem and/or clog in the drain line.You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
Thanks and take care
May 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 error code on display board the Whirlpool Duet front load washer. Checked the drainage filter and line and it does drain just fine with the wet vac with no blockages noted. Does this sound like the...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Received a F 02 error code which is a draining problem. Checked the hose and it was clear. Upon restart, drum won't spin. Can hear motor engaging. Recommendations?
Sounds like it's not draining the water so the load is too heavy for the drum to spin. Remove the lower panel (3 bolts facing outward on bottom of panel), unscrew the lint filter trap (right side), and clean it out. Also make sure hoses are okay, and that the drain pipe is not clogged.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,773 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
