Question about Dryers
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
  • 736 Answers
The gas dryer has several temperature sensors in the air flow stream .. they normally regulate at the selected drying temperature by turning on and off the gas .. if there is a lack of air flow then they quickly heat up and shut off the gas .. when they cool the gas comes back on ..the dryer likely will cycle on and off fairly fast when its clogged.... so your problem is "lack of air flow" .. that can be caused by the lint screen or its pathways being clogged .. or more likely and harder to see is the vent pipes or pathway to outside .. the flex (or solid) tubing coming out of the dryer should be removed and cleaned or replaced at least a couple times a year .. there are special big round brushes available .. these are mounted on a rope or extension wand .. you can push or pull these thru the vent pipes to clean them .. make sure the outside flapper is not stuck or clogged ..
Posted on Aug 01, 2009
  • Dryers Master
  • 1,606 Answers
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
My drier has no heat. I don't here the gas kick in.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./
Sep 18, 2011 | Whirlpool WGD6400S Gas Dryer
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
heatman101
Aug 21, 2011 | Whirlpool Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
I can hear ignter kick in at first dries for a few min. then goes cold no heat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Whirlpool WED5520SQ Gas Dryer
Model #leq9508lwd dryer heat will not kick off!!!
heatman101
Sep 04, 2010 | Whirlpool LEQ9857L Electric Dryer
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
Whirlpool accue temp dryer gets hot then heat shuts off
Sound like you need a new agnitor for your dryer take the model # to order part and install very carfully good luck
May 09, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Whirlpool gas dryer wont heat up
Hi!!! you seem to have a problem with the coil boosters..located above the gas valve..Its shown here .Good luckk..8035205.jpg
Jan 21, 2009 | Whirlpool LGR6636 Gas Dryer
Dryers Logo
129 people viewed this question
Top Dryers Experts
