Question about Boating
No start on 2002 1200 xlt yamaha waverunner
Thing was working great and then all of a sudden dies on me. Wanted to try to turn over and then soon juiced out battery. Charge battery up and now just clicking sound from relay in fuse box. I have read many scenario's just like this but read no answers. Think im gonna replace the relay but thought i;d post this first. Any help wor suggestions would be much appreciated.
  • jmkr1122 Mar 25, 2010
    did u figure out the problem? I'm having the same problem.
  • Aaron Bleeker
    Aaron Bleeker May 11, 2010
    After it died and you tried to turn it over, did it turn or not?
Loringh
  • 185 Answers
SOURCE: I was driving home and
Ladytkk:
The clicking sound is the starter solenoid (a relay) trying to connect the starter to the battery. This is normal when the battery is run down. the first thing to do is to see if you can charge the battery.
If you do not have a charger, see if you can borrow one. BTW, a small charger is a good thing to have, especially if lights or etc are left on and your battery is dead when its time to go to work. You can get a small one at a Walmart like store for a reasonable fee. Connect the red lead of the charger to the red (+) terminal of the battery and the black lead of the charger to the black (-) lead of the battery. Let it charge for at least 5 or 6 hours. Unplug the charger, disconnect it from the battery and try to start the car. It will probably start. At first opportunity, drive the car to one of the major auto parts stores like AutoZone and have them load test the battery. If you need a new battery, most stores will install it right there.
Hope this helps Good luck Loringh Please give me a rating Thks
Posted on Nov 09, 2008
  • 1201 Answers
SOURCE: 2001 jimmy not starting
You can try this==== take a screw driver and tap on the relay switch with the handle while somebody is turning the ignition. This is only a test, not a definate solution. If you haven't already, check the starter solonoid. My opinion, if the ignition was bad, it wouldn't even click at the relay, but without testing it's hard to say.
Posted on Jan 25, 2009
SOURCE: Waverunner will not start
Check the fuses under the front in a round cover, 1 fuse is for the starter,but the cover must be on after checking the fuses.
Posted on Jul 13, 2009
  • 24 Answers
SOURCE: waverunner sat for 4 months. thought battery was
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Posted on Jul 14, 2009
  • 4088 Answers
SOURCE: car wont start clicking noise by fuse box
Try removing the battery terminals and clean both posts and terminals. Coat same with an anti-corrosion grease. Wash your hands after this to prevent mysterious holes in your clothes. Start the engine and measure the voltage at the battery terminals--should read 13.5 to 14.5 volts. Hope this helps.
Posted on Sep 06, 2009
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Have a 1999 yamaha 1200 xl limited waverunner only clicks at the starter relay when trying to start it after a friend forgot to put the plugs in and it got water in the engine compatment
your starter is shot more than likey try to jump the relay in that black boxs buy jumping the two post on that round relay if it does the same its the starter if it turns over its the relay or the start **** becareful jumping the relay no fuel around air bike out and you have to take off the exhaust manifold to get to the starter
Aug 01, 2010 | Boating
Strong vibration 2004 yamaha xlt waverunner
Something was stuck to the intake obstructing flow.
When you shut it off it drifted away.
It is a good practive when in weedy or heavy debree areas to get clear shut the motor off count to 30 then restart and gradualy excelerate to make sure it is clear. used this method for ten years now and seems to work well for me.
Jul 21, 2009 | Water Sport
Boating Logo
274 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
