Question about Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards
Hessitation when accelerating
1999 40 HP Mercury Bigfoot, A Real pain to drive it will go to full throttle eventually,you have to feather the throttle slowly or the engine will stall or just kinda sit there till it "catches its breath"
Does anyone have any Ideas on what it needs to fix this
ThanksMike
  • 86 Answers
Sounds like you have either old fuel in the tank, wrong fuel/air mixture, or plugged carberator jets. First thing that I would try is to adjust the fuel/air mixture. Near the top of the carb on the front or the side there is a slotted screw. Turn the screw all the way in until it seats. Then turn it counter clockwise 1 1/2 turns. That is your start point. Then with the engine at an idle in gear slowly turn the screw clockwise until you hear the engine start to die. When it when it sounds like it is going to die turn back out 1/2 turn and it should smooth out. this is your correct mixture and should be readjusted anytime you rebuild the carb or run at a different altitude. Second thing that I would try is while running engine get the RPM's all the way up and while still maxed out pull the choke knob out and when it is about to die push knob back in. That will cause a vaccuum inside of the carb and possibly clear jets out. If that doesnt work then I would pull the fuel bowl off of the carb and make sure it smells like fresh fuel and not old fuel. Old fuel has a very distinct smell. if the fuel smells old then you need to have the carb rebuilt and that should be done by an outboard mechanic.
Posted on Aug 02, 2009
How to drain carb bowls on 1999 mercury 2strock 3cyl 60hp outboard
Hey Geoff,,, there is a "bolt" on the side of the float bowl,, unscrew and remove it,, gas should flow out, freely.,,while the "bolt" is out.. pump the bulb and this will help flush out some crud..BUT - For a complete cleaning,.. you need a qualified professional... its #25 on the diagram Parts for Mercury Marine 60 HP Bigfoot 3 Cylinder Carburetor
Jul 04, 2017 | Mercury Boating
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
Mercury 60 Big Foot outboard
you can adjust the throttle position better than what you have described
the first forward action is the gear engagement and the at least 1/2 " lever movement before the engine starts to rev up
the same for reverse
that gives more control over the required rpms
Jun 02, 2017 | Boating
My friend owns a 1995 Mercury Mystique.She had a new starter put in and after that the car will start but you cannot rev up the engine to drive it. If you rev it up very slowly the engine will rev,but if...
replace the fuel filter, first, if there is no check engine light, if that does not fix the problem ck the fuel pressure for possible fuel pump failure
Sep 01, 2013 | 1999 Mercury Mystique
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
2005 mercury 9.9 hp bigfoot motor
does it get faster with speed the clicking ? could be a bearing !
Apr 28, 2013 | Mercury Four-Stroke Outboard Motors, Model...
2001 crown vic 4.6l maybe twice a week i go to crank the car and it sputters real bad and eventually dies. After it dies i clean the throttle body and then it runs fine. What is causing this?
I would replace the dle Air Control solenoid. I know its a guess, but its a common thing. when cranking the engine, the idle should flare high, and then slowly down to idle speed.
Dec 06, 2010 | 2001 Ford Crown Victoria
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Logo
459 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
