Question about Muratec Office Equipment & Supplies
My muratec model 2010 has LAMP ERROR THAT IS ALWAYS RECURRING
Reset code for muratec mfx 2010
Is it the drum counter? You can only reset when you put a new drum it it.
http://www.fixya.com/support/t18621752-muratec_mfx_2010_reset_drum_amp
Jan 04, 2016 | Muratec Office Equipment & Supplies
Settings on muratec mfx 2010
How can I fix the black paper when I copy in muratec mfx2010 ... I mean when I copying a paper.... the paper I get its all black
Mar 09, 2012 | Office Equipment & Supplies
Call servce 18 muratec mfx 2010
muratec mfx 2010 call service 18 problem
Oct 14, 2011 | Muratec Copier
Model mfx 1950 "calibrating scanner"
Refer to your "users guide" that came ith the machine... in particular refer to pages 1-14 thro 1-17 of the guide and ensure you have the date and time set correctly.
On page 1-17 you will see reference to "energy save interval" and sleep periods for the lamp. If you do not have these programmed correctly you will experience the condition you are describing.
This is a relatively new model...if you have already lost the manual you can download it from Muratec's Web site www.muratec.com.
Apr 09, 2010 | Muratec Copier
Muratec 1430 Lamp Error
This may be a case of "older software" there were numerous software updates to the 1430...the last being Dec'2007 upgrading to a software level D6AOAO.
You can print out a Consumable Order Sheet to check the ROM version of your machine.
Press...SETTING, *,1, 5. Select "OrderSheet List" when printed..at the lower Right hand corner is the Rom version, if it is A ****, OR B****
or lower than D6 then it is likely the software needs to be upgraded...this will require a service technician with a Laptop to do the software upgrade.
May 21, 2009 | Muratec MFX-1430 Copier
Paper jam message but there's no paper
There should be an exit sensor, as part of the fuser unit, I suspect it either has not been connected or is physacally jammed out of position. Check these areas, and also for pinched wires.
Hope this helps.
Ed
May 07, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
125 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Scott Yeoman
Ed
Ed
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
