Question about Toshiba TN55V71 55" Rear Projection Television
Will not come on at times, will click 3 times and shut down with red light in front flashing.
  • 34 Answers
Check the power supply section for leak filter capacitor 160volts and 100micro farrads.and check or change in actual the auto coupler.
Posted on Aug 01, 2009
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
Light: red click light :green 1 sec later shut down light:red no flashing light
YELLOW LIGHT OF DEATH (YLOD) You need to strip your machine down to the motherboard and reflux and reflow the board.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
It just shut right off in the middle of playing. I get a flashing red light on the front of the PS3. When I press the power button it goes to solid red. Then if I try to turn it back on it tries to fire...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
click here
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Upon start-up shuts down and flashes red light on front panel
first take your ps3 to your nearby shop ,,,,,,, if the same problem exists use repair guide to fix this problem............................
click here to download repair guide.....................................
Sep 11, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 will not work - powers itself down
Hardware Failure. You can try using some of idea from this guide:
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=3290911
MAJORITY of the time it's a GPU problem though that only Sony or very experienced techs can fix.
You can reach SONY @ 1-800-345-SONY
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Flashing red light
Go to you www.youtube.com and you may be able to find helpful videos on this. But if you bought it new it is under warranty and they will fix it. You just pay for shipping.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
Toshiba TN55V71 55" Rear Projection Television Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
