Question about Qca Spas Majestic Series Aruba Xl Hot Tub
There is a crack in the manifold of my Majestic Series E. It is an 8 port...2in to 1/2in. Where do I find a replacement part?
  • 631 Answers
A wrecking yard would be the cheapest route to go.
Posted on Aug 01, 2009
How do i find instructions for idect majestic single handset phone
Hi, Click on the link below and then click the 3rd down [PDF] USER GUIDE. It will automatically download the manual for Idect c5i system
://www.google.com.au/search?q=for+idect+majestic+single+handset+phone&oq=for+idect+majestic+single+handset+phone&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8#q=user+manual+for+idect+majestic+single+handset+phone
Mar 18, 2016 | Lands Phones
What is the sum of 17in 12in, 81/2in,12in and 8 1/2in
90 in or you can convert that in 7ft and 6in
Oct 14, 2014 | Computers & Internet
Draining a QCA 8-person jacuzzi
Hello, there is no drain plug. You will have too siphon it out with a hose or a sump pump.
May 19, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
Intake hose on egr valve had antifreeze in it
not a good sign. which engine, 8valve or 16v? MATTERS BIG TIME.
do you run 50% Antifreeze (AF) or just hope it dont freeze and crack the head.? (anything with AF in it can crack, anypart)
the EGR has only 3 ports.
1 is vacuum
the other 2 are exhaust.
my guess is that you removed egr, (you forgot to say)
and the black carbon ports , in valve dripped green AF.
right?
that means the intake manifold is cracked, and AF is pouring
in to there, or the head is cracked.
end story.
if the vacuum hose (you didnt say ) is full of AF, that is near impossible. its a very tiny hose.
use this page to find the correct part, and say where it leaks exactly
or post photo of object.
8v or 16V?
the 8v EGR is below the TBI
the 16v is at the rear (MPI) intake manifold very hard to get to.
http://www.fixkick.com/find-parts.html
ill take a wild guess.?
and its 8 valve engine.
part #1 EGR leaks
or was it REALLY the ISC?
the ISC has 3 hoses, not 1, , one is air, 2 are AF (water)
http://www.fixkick.com/sensors/8v-sensors.JPG
post back and we can do other tests. like compression test
or radiator leak down test. (fumes test)(
Mar 31, 2014 | 1995 Geo Tracker
Water dripping out of 1/2in. bent pipe coming out of area below intack manifold.Is this a big job?
Make sure this is engine.There should be a tube that allows moisture to drain from the AC system .
Apr 05, 2010 | 2000 Buick LeSabre
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Location of low side A/C port on 2001 Lincoln LS V8
2002 is what I have. should be similar
Service Gauge Port Valves
The high-pressure service gauge port valve is located on the A/C receiver drier manifold and tube assembly.
The low pressure service gauge port valve is located on the manifold of the A/C compressor manifold and tube assembly at the A/C compressor.
23d30e7.gif Item Part Number Description 1 19860 A/C evaporator core 2 19849 Thermostatic expansion valve 3 19A834 Manifold and tube assembly—thermostatic expansion valve 4 19D850 Manifold and tube assembly—A/C compressor 5 19E762 A/C charge port valve (low side) 6 19E762 A/C pressure relief valve 7 19703 A/C compressor 8 19D594 A/C pressure transducer 9 19712 A/C condenser core 10 19D701 A/C charge port valve (high side) 11 19N585 Manifold and tube assembly—receiver drier 12 19959 Receiver drier 13 19C734 Sensor—evaporator air discharge temperature
Jun 11, 2009 | 2001 Lincoln LS
Coolant in # 1 cylnder\clean intake port of intake manifold
Check the lower intake gasket again the new gaskets that are being use made out of plastic with rubber port seals sometimes don't seal right I still used gasket sealer with the new plastic gasket even if it has rubber seals. MY 4.2 v6 had that problem but I went ahead and replaced the head gaskets also just to cover all the bases. And my F-150 has 210,000 miles on it. Make sure you tight the bolts I know it probably calls for something like 8 ft lbs which to me is not tight enough. Double it.
Apr 18, 2009 | 2000 Ford F150 Flareside SuperCab
1998 grand cherokee spark plug firing order
normally to repair a cracked manifold its just as expensive to get a new one because manifolds are cast iron, you can get a new one from ebay for 30 bucks apposed to 100$ to have it welded with special matieral here is the firing order
| 2 4 6 8 |
| | 8 ||
| | 1 4 ||
front | |2 3||
of | | 7 6 ||
motor | | 5 ||
| 1 3 5 7 |
Jan 25, 2009 | 1998 Jeep Cherokee
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
152 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
