Question about Thermos Grill2Go Fire+Ice
Where can i find new regulator - Thermos Grill2Go Fire+Ice
  • 154 Answers
Home depot,loews
Posted on Aug 02, 2009
On a Go-Anywhere grill 20+ years old, the regulator valve slides out of the grill even when facing upwards. Normally only does this facing downward. Is there wear on my regulator? Or is it in the tube...
The U shaped clip that holds the regulator to the gas tube is probably missing.
Make a new one with a LARGE size paper clip bent with needle-nosed pliers and stick each end of the "U" shaped new wire into both sides of the gap in the gas tube where there is a groove in the regulator when the regulator is pushed into the gas tube. The simple new clip will prevent the regulator from sliding out.
Jun 16, 2011 | Weber Gas Go-Anywhere Grill
If i put a little gas in the carberator and fight with my blazer it will start and stay started, but if i leave it for awhile, it will turn over but not start. i cant figure out if it is electric or...
Get a fuel pressure gauge and connect it to the rail for the fuel injectors to read pressure.
If the pressure is too low, it might be a bad fuel pressure regulator or pump:
Fuel Pressure Regulator Removal & Installation 2.2L Engine To Remove:
  1. Relieve the pressure in the fuel system.
  2. Disconnect the negative battery cable.
  3. Disconnect the vacuum hose from the fuel pressure regulator.
  4. Remove the pressure regulator mounting screw.
  5. Remove the fuel pressure regulator assembly with O-ring. Inspect filter screen for contamination. If contaminated, remove and discard.
Fuel pressure regulator removal/installation (2.2L SFI engine) gm-05-22-619.gif
To Install:
  1. Apply clean engine oil to the new pressure regulator O-ring and install the O-ring on the regulator.
  2. Install the regulator on the fuel rail. Apply thread-locker to the mounting screw.
    • Tighten the screw to 106 lb in (12Nm).
  3. Connect the negative battery cable.
  4. Use the following procedure to pressurize the fuel system and check for leaks;
  5. Turn the ignition ON for 2 seconds.
  6. Turn the ignition OFF for 10 seconds.
  7. Turn the ignition switch back ON to run the fuel pump again and pressurize the fuel system.
  8. Check the fuel rail assembly for fuel leaks.
4.3L Engine RPO L35 To Remove:
4.3L (RPO L35) Fuel meter body assembly gm_trk_sil15_02-04_43_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section
  2. Remove or disconnect the following:
    • Upper intake manifold (See: Upper Intake Manifold)
    • Fuel pressure regulator retainer clip (M) and discard the clip
    • Regulator (N) from the housing by twisting and pulling the fuel pressure regulator (N) and using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (R) and discard the O-ring seal
    • Regulator filter (Q) and discard the filter
    • Regulator seal O-ring (P) and discard the O-ring seal
    • Backup ring (O) and discard the ring
  3. Cover the fuel pressure regulator housing to prevent contamination from entering the fuel system
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil
  2. Assemble the following new parts to the fuel pressure regulator:
    • Backup ring (O)
  3. Install or connect the following:
    • Fuel pressure regulator with the vacuum tube pointing down
    • Upper manifold
  4. Test drive the vehicle to confirm the repairs
RPO LU3 To Remove:
4.3L (RPO LU3) Fuel meter body assembly gm_trk_sil15_02-04_43_rpolu3_fuel_metr_body_assy.gif
    • Fuel pressure regulator retainer clip (E)
    • Regulator (F) from the housing by twisting and pulling the fuel pressure regulator (F) while using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (J) and discard the O-ring seal
    • Regulator filter (I) and discard the filter
    • Regulator seal O-ring (H) and discard the seal
    • Backup ring (G) and discard the backup ring
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil.
    • Backup ring (G)
    • Fuel pressure regulator (F) with the vacuum tube pointing down
Nov 04, 2010 | 2002 Chevrolet Blazer
I have a 2004 Tahoe which has misfire problems (P0300). I changed the plugs, wires, fuel filter and air filter but problem still exist. The 4 plugs on the passenger side continue to file out and become...
Removal & Installation of fuel Regulators on
4.8L, 5.3L & 6.0L Engine To Remove:
CAUTION
Three styles of fuel pressure regulators and fuel rails will be used in this model year. Each regulator has a different "footprint" that consequently changes the size of the receiving port in the fuel rail. The regulator retaining clips are specific to each rail-regulator design and cannot be interchanged.
  1. Remove the engine sight shield.
  2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
  3. Clean the fuel pressure regulator retainer and the surrounding area.
  4. Remove or disconnect the following:
    • Fuel pressure regulator vacuum line.
    • Fuel pressure regulator retainer.
    • Fuel pressure regulator.
  5. Remove the following parts from the fuel rail:
    • Backup ring (10)
    • Regulator Seal O-ring (11)
    • Regulator filter (12)
    • Regulator seal O-ring (13)
To Install:
  1. Make sure the NEW fuel pressure regulator retainer is the right one.
  2. The tabs (1) are used on the straight vacuum port retainer (2), and the E85-straight vacuum port retainer (3).
  3. The angle vacuum port retainer (4) has no tabs. chevy_aval15_02-04_fuelrail.gif
  4. Install the following parts onto the fuel pressure regulator (9).
    • Backup ring (10)
    • Regulator seal O-ring (11)
  5. Lubricate the fuel pressure regulator O-rings with clean oil.
  6. Install the fuel pressure regulator and retainer. CAUTION
    Whenever the fuel pressure regulator is removed from the fuel rail NEW O-rings and a NEW retaining clip should be used on reinstallation.
  7. Connect the vacuum line.
  8. Tighten the fuel filler cap.
  9. Use the following to inspect for leaks:
    • Turn ON the ignition, with the engine OFF, for 2 seconds.
    • Turn OFF the ignition for 10 seconds.
    • Turn ON the ignition, with the engine OFF.
    • Install the engine sight shield.
8.1L Engine To Remove:
Fuel pressure regulator vacuum line gm_trk_sub15_fuel_press_reg_vac_line.gif
  1. Before servicing the vehicle refer to the precautions at the beginning of thjs section
  2. Remove the fuel injector sight shield as needed
  3. Relieve fuel system pressure (See: Fuel Pressure Relieving)
  4. Disconnect the fuel pressure regulator vacuum line (A) 8.1L Fuel pressure regulator retainers gm_trk_sub15_81l_fuel_press_reg_retainers.gif
  5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area
  6. Remove the fuel pressure regulator retainer (I)
  7. Remove the fuel pressure regulator (H) from the fuel pressure regulator housing
To Install:
  1. Install or connect the following:
    • Backup ring (J) on the fuel pressure regulator (H)
    • New large O-Ring (K) on the fuel pressure regulator
    • Regulator filter (L) on the fuel pressure regulator
    • New small O-Ring (M) on the fuel pressure regulator
  2. Lubricate the fuel pressure regulator large O-Ring and the small O-Ring with clean engine oil
  3. Push the fuel pressure regulator onto the regulator housing on the fuel rail
  4. Install a new fuel pressure regulator retainer (I)
  5. Install or connect the following:
    • Negative battery cable
  6. Tighten the fuel filler cap
  7. Inspect for leaks using the following procedure:
    • Turn on the ignition with the engine off for two seconds
    • Turn off the ignition for 10 seconds
    • Inspect for fuel leaks
  8. Install the fuel injector sight shield
  9. Road test the vehicle to check performance
Sep 02, 2010 | Chevrolet Tahoe Cars & Trucks
Locating fuel pressure regulator
To Install:
To Install:
    • Backup ring (O)
    • Upper manifold
RPO LU3 To Remove:
To Install:
    • Backup ring (G)
Aug 05, 2010 | 2001 Chevrolet Blazer
How to install a new regulator?
You can buy the regulator at Home Depot. Just cut the gas hose off at the old regulator and put new regulator on with a hose clamp. $200.00??? Somebody is trying to rip you off !!!!!
Jul 23, 2010 | Weber Genesis Silver B Grill
When changing out a window regulator can you change out the spools without having to purchase a new motor
yes. spool comes with regulator, all you do is remove motor and reinstall on new regulator, hope this helps.
Oct 06, 2009 | 2004 Ford F150
What is the procedure for replacing rear window regulator on a 2003 VW beetle convertible.
.leave window up half way.tape window to hold it.remove door panel clips.rip out foam moudling.drill out rivets holding regulator.remove connector.remove regulator clips.remove regulator.put in new regulator and clips.put in new rivets.plug connector.test it.if all is good install moulding and door panel.
Oct 04, 2009 | 2003 Volkswagen New Beetle Convertible
Driver side window regulator
I would suggest replacing the whole regulator. They do offer the plastic slide pieces seperatly but usually the regulators bend and cause premature breakage of new component. If you can just replace the slides-remove the regulator and drill out existing piece if it is broken off in regulator. Next take a ball peen hammer and peen new metal into a mushrrom to secure it to existing regulator. I would remove the slider from the glass and push window all the way up and secure with a suction cup to keep it from falling down. Then take off the 2 screws securing the motor harness(disconnect the battery because one wire is hot and pay attention to the placement of the wires when they are resecured-it will just work in the opposite fashion if the polarities are reversed). Then take out the nuts and bolts securing the regulator to the door frame. If you figured out how to take off a 126 door panal you should be able to figure out the regulator position in the shell. Once the regulator is out remove the motor and secure it to the new regulator. Inspect the teeth on the motor and lube with grease (white lithium grease is what I use-wheel bearing grease is fine but it can be messy). Then "fish" new regulator into the door and secure nuts(use red locktight so they do not loosen up in the future).Then slide window down and slide in new plastic slides into window glass frame-you will want to leave the regulator loose and may have to start one of the slides before you secure regulator to door. Lube up the run channels and slides with grease. Snug regulator and operate window with regulator partially loose to let window find the best position with the lease stress and then secure regulator. It isn't as bad as it looks and with a new regulator it will be more self explanitory. Worse case senario remove the other rear panal and copy that regulator position. Good luck I hope I have been helpful.
Aug 08, 2009 | 1990 Mercedes-Benz 300 Diesel
How do I install a new windows motor- to include the cable drum (drivers side). The old motor burned up and the cable broke. Thanks Hans
You'll need to buy a new motor and regulator. You can go used or new, it's up to you. The regulator will include the cable.
- Remove the interior door trim,
- Disconnect the power cable from the window motor,
- Remove the window bump-stops (one at the front, one back),
- Remove the glass window from the regulator (two bolts),
- Slide the glass window out of the top of the door,
- Remove 3 nuts from the window motor,
- Remove all window regulator bolts,
- Slide the motor & regulator assembly out the top of the door.
- Mount your new motor to your new regulator,
- Install the new motor & regulator assembly in the reverse order.
Jul 27, 2009 | 2003 Hyundai Tiburon
How to replace a fuel pressure regulator
the fuel pressure regulator is on the end of the fuel rail it is held on by a torx screw relieve the fuel pressure using the schrader valve on the fuel rail remove regulator holding screw and replace new regulator be carful not to damage o-rings on new regulator
Nov 02, 2008 | 2004 Pontiac Grand Am
Thermos Grill2Go Fire+Ice Logo
190 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
