Question about Fedders A6U10W7A Thru-Wall/Window Air Conditioner
Window ac leaking at bottom - Fedders A6U10W7A Thru-Wall/Window Air Conditioner
    President:
  • 1,124 Answers
It is normal for water to exit out of the bottom.. That is the condesation from the dehumidifying action.. However the untit should be tilted stighly toward the back of the unit so it drips out side..
If the water is "leaking" out of the bottom at a place that should not be - it could be that a portion of the (should be dealed bottom) has a breach.. Ifs thats the case - remove the cover - find were the "leak" is and patch it with some glue..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Posted on Aug 01, 2009
Can ac condensor leak water on ss cobalt at bottom of pass side or could it be radiator leaks in front of duel fans
The a/c condenser doesn't leak water, but it certainly condenses the moisture out of the air (hence the name). The HVAC box is supposed to have a drain installed at the bottom to allow the condensation to run out (usually via a hose through the firewall). If this drain is blocked, the condensation will accumulate and leak into the passenger compartment.
Apr 17, 2018 | AC Cars & Trucks
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
What is causing water to leak down onto the floorboard of my 2004 Mazda 6 when I have AC on?
this will be condensate from the fins of the ac evaporator in the car and is leaking onto the floor because the drain on the unit is blocked either in the hose or at the bottom of the ac box
Aug 24, 2014 | 2004 Mazda 6 Wagon
Leaking ac
Hello, if this is a window AC make sure the unit is tilted back in the window about a 1/4 inch. Also, if there is a drain outlet make sure itnis not blocked and not allowing the condensate to flow.
Jul 07, 2012 | Maytag Heating & Cooling
I have a frigidarie window air conditioner with drain hole in the bottom that leaks is there a drain hose and hose adaptor that can be purchased if so where
If you cant do any better, cut a piece of plastic or flashing material and insert it under the ac so that the dripping water will fall on it and away from the building. If you make it long enough you can insert it under the unit in such a manner as to pinch it and hold it in place. You can bend it to suit. I have a number of houses with window units. The first thing I do when I get a replacement unit is pull the cover and drill a hole or two, 3/8 to 1/2. The largest I can drill and not touch the coils.
May 06, 2012 | Heating & Cooling
Air conditioner suddenly not working.. No funny noise, just acts like it is not getting power. compressor kicks on and off checked relays behind glove compartment. Was told ac relay may not located with...
AC COMPRESSOR KICKING OFF AND ON.SOUND LIKE REFRIGERANT LOW.LOW SIDE SHOULD BE 20 - 36 PSI AND HIGH SIDE SHOULD BE 215 - 310 PSI. AC SYSTEM COULD HAVE A LEAK WHILE YOUR COOLING STOPPED. DRIVER SIDE WINDOW MOST TIME SWITCH WILL BE THE PROBLEM.REMOVE SWITCH SEE IF POWER GOING TO POWER WINDOW MOTOR.YOU HEAR WINDOW MOTOR TRYING TO WORK WHILE USING SWITCH.WINDOW REGULATOR COULD BE BINDING DAMAGED OR NEED LUBRICATING.OR MOTOR NEED REPLACED.IF POWER NOT GOING TO POWER WINDOW MOTOR THE CONTROL SWITCH IS BAD IF ITS THE ONLY SWITCH.TO TELL IF WINDOW SWITCH IS BAD SHAKE POWER WINDOW SWITCH WIRES WHILE OPERATING CONTROL SWITCH.IF POWER WINDOW WORKS YOU KNOW SWITCH IS BAD.TAKE CAR TO AC SHOP BECAUSE LET THEM CHECK AC SYSTEM BECAUSE IF YOU BUY 2 CANS OF R134 REFRIGERANT. AND YOU TRY CHARGING AC SYSTEM YOUR SELF AND ALL REFRIGERANT LEAKS OUT. YOU GOING TO BE OUT OF $30.00 STILL NO AC.THAT WHY ITS BEST TO LET SHOP PUMP DOWN AC SYSTEM CHECK FOR LEAKS BEFORE RECHARGING AC SYSTEM.
Jun 26, 2011 | 2000 Acura TL
I don't know how to uninstall my ac
have some one steady the unit while you raise the window a bit.carefull,it may want to fall out.pull the bottom of the unit in a bit.if that dosen't change the angle,like if it's sitting on a storm window frame too,place a wood plank between edge of sill & storm window frame to raise the inside bottom of unit a bit above the sill.it only requires a few degrees of tilt.
Sep 22, 2009 | Heating & Cooling
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
Leaking water
If you are running the AC often, it is a plugged HVAC drain. Find the drain under the truck. it is on the firewall -black rubber. clean it out with air and you will be good to go.
If it's got coolant in it, you have a leaky heater core connection. you may need new seals where the lines connect to the core.
Jul 31, 2009 | 1989 Chevrolet S-10 Blazer
Fedders A6U10W7A Thru-Wall/Window Air Conditioner Logo
87 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
