Question about Philips 27PT6441 27" TV
I am having the same problem with my t.v. It is a phillips model 27PT6441 power light blinks repeatedly when turned on and no picture? Can you help?
    Novelist:
  • 133 Answers
Probably some power supply trouble (could also be elsewhere).
Check for:
- inflated or blown electrolytic capacitors - replace these
- bad solder connections on ANY of the components (resistors, coils, diodes, transistors, ICs, etc. - if anything has been heating up, the circuit board wil look somewhat darker around those components) - resolder bad connections
- burnt our resistors or any other component (this might require some measuring, perhaps a schematic if any components are damaged in such a way that makes it impossible to read the type or value of the component).
-also, if a capacitor is niether inflated nor blown up, it might still be dried up even if it looks good, but, in such a case, it will tend to heat up. Check this by turning the TV on, let it blink for a minute or so, turn the power off and quickly DISCONNECT FROM POWER OUTLET, then see if any of the capacitors has been heating up by touching its top with a finger (you obviously need to do this with the cover removed and need to BE VERY VERY CAREFUL, there may still be high voltage present, so don't touch anything on the picture tube neck, and it's not a bad idea to put latex gloves on your hands to insulate them when you touch the capacitors or anything else).
Hope you can find out what it is, and please, do take care, i don't want to be held responsible for people getting electrocuted as a result of my suggestions.
regards
3rq8 (Triarcuate)
Posted on Aug 01, 2009
My Phillips model number 27PT6441/37 tv doesnt come on when u push power. Instead power indicator flashes a total of six times. 2 flashes,then 3 flashes,and then 1 flash. What does this indicate?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jan 04, 2017 | Televison & Video
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
T.V won't turn back on
Sounds like a component shorted out for sure. I will guess he will say, "It needs a new power board". I would guess a transistor or microchip burnt out. Probably ESD damage from a new factory worker.
Nov 14, 2008 | Televison & Video
Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Sep 10, 2008 | Philips 27PT6441 27" TV
Philips power green blinks and no picture
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions.
Jul 07, 2008 | Philips 27PT6441 27" TV
Philips 27PT6441
This is a very common problem on this model. Where are you located ?
Jun 23, 2008 | Philips 27PT6441 27" TV
27PT6441 27 " TV problem
Jun 22, 2008 | Philips 27PT6441 27" TV
Phillips TV 32PT5441/37
Jun 19, 2008 | Philips 27PT6441 27" TV
Phillips TV model # 27PT6441/37 issue
Apr 23, 2008 | Philips 27PT6441 27" TV
Philips 27PT6441 27" TV Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
