Hp psc 750xi - trying to scan - printer screen says options not set - how do i set the options - please
  • lee Aug 01, 2009
    a while back - should i uninstall & reinstall?? printer was given to me by a friend - can i go to hp for the drivers? know just enough to be dangerous - thank you in advance -
  • 724 Answers
Did you completely do an install printer and scanner drivers?
Posted on Aug 01, 2009
I have a new computer with windows 7 premium 64 bit and a hp psc 750xi all in one printer how do i get the drivers to have my printer work
  1. Navigate to the HP website. http://www.hp.com.au
  2. Click on the Support and Drivers section, located at the top right of the page.
  3. In the for product field - type in: HP PSC 750xi All-in-One Printer. Press <Enter>.
  4. Click the Software and Drivers Download link.
  5. Click the link Microsoft Windows 7 (64 bit).
  6. Click on the link that says, Installing the Product with the USB cable ...
  7. Here you will find HP's solution to the problem.
Note: HP have not updated their drivers for this printer for use with Windows 7. You will be able to get basic functionality from your printer, but not all of the features of your printer. You may wish to shop around for another printer. If you do, make sure you check what systems the printer works on (i.e., xp, vista, windows7) etc...
Regards,
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
My hp psc 750 all-in -one printer scanner not working
A friend of mine had a HP printer (Not a PSC 750) that he had simply plugged into his computer and was able to print properly but received the "options not set" message when he tried to scan.
The solution was to install the HP driver package for his printer.
If you are using the default Windows drivers for your printer you may need to install the HP driver package to access all of your printers functions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&custom_solutionid=rd_bpu04809&product=57769
Mar 03, 2009 | HP PSC 750 All-In-One InkJet Printer
Can't scan from HP psc 2400 to iMac computer
You need to set up the software on the iMac. The reason it gives you that error message is because it can't communicate with the computer and imaging software as the computer doesn't see the scanner and can't communicate with the printer's control interface. The iMac may see the printer and be able to print without any additional software because the driver package for the printer portion may already be installed with the OS X HP printer driver support. You didn't mention whether or not you could print from OS X. I am assuming you can. Faxing and copying from the unit doesn't use the computer at all and doesn't need to communicate with it. Scanning and printing do. If you can't print either then none of the driver or support software is installed and you have to set it up. You can get the instructions for setting the printer up in OS X 10.5 from HP. Just click here and it will take you to the page with the instructions.
Best wishes and cheers
Jan 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp 750xi scanner failure
Try the hp site:
I was having the same problem but ended up being able to scan using Windows Photo Gallery and my HP 750xi. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&lang=en&product=58917#Workaround
Dec 04, 2008 | Office Equipment & Supplies
How do I access the ink jets?
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see and indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the carrage.
Oct 06, 2008 | HP PSC 750xi All-In-One InkJet Printer
Hp printer scanning prblm
Are you able to make copies only (just press copy color or copy balck and check)
And are you able to scan pictures.
If yes then make sure you are scanning from HP Director as Scan documents and follow the on screen direction.
If you do not get the option to scan documents then in HP Director go to> Settings> Scan Documents settings> You will see a option saying promt for these setting at the time of Scan> Put a check mark on that and click on Apply and ok and then try scanning document.
If this does not work the go to Start> Control panel (or Start> Settings> Control panel> Then printer and other hardware or Scanners and cameras> then Right click on the Printer icon> and scan from the options there.
Good Luck
Aug 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp 1315 won't scan
Are you able to scan from the software installed in the computer:
If you have a icon saying HP Director / HP Solution center, if not go to Start> All Programs> HP And then HP DIrector / HP Solution Center and then try to scan from there if yopu are able to scan from there then go to> Settings in HP Director / Solution> Then Scan to setup> You should see a option which says Destination list> There down bellow you should see a option which says RESTORE DEFAULTS> Click on that and then apply> and close all the screens and try to scan from the All-In-One printer.
Good Luck
Aug 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
178 people viewed this question
jasbo
jasbo
