Question about Sony Cameras
DSC-1700 soNew Problem - Troubleshooting Forum - Product Support
I got water on the lens of my sony digital camera and now it don't project and don't take pictures everything else is working will it work when its compliantly dries
SOURCE: My digital Sony camera fell down Lens got stuck
the lens on my Hp R717 Camera got stuck so when I turned it on, it would shut off automatically. The shutters were stuck too so I extended the lens using a flat screwdriver and then shut it, and kept doing that until the lens finally shut.
Posted on Sep 15, 2007
  • 28 Answers
SOURCE: DSC-W90 Sony Digital Camera - Lens Error
Sorry man, I think you're out of luck. Most likely nothing you can service, maybe a professional can fix it though. Still under warranty? Good luck.
Posted on Nov 09, 2007
darntoothysa
  • 489 Answers
SOURCE: Digital Camera
Hi
E:61 is a Sony error code for a problem with your lens.
Initializing the camera will put all the settings back to default which can sometimes fix a camera that will not power up or does not function properly in other ways. I love Sony models that have the "Reset" button either inside the battery compartment or on the bottom of the camera, I don't have a T70 on hand to tell you if you have a reset button or not, but if memory serves I do not think you do.
If 'Initializing' the camera does not work then the next step would be to try replacing the lens. If it's still under warranty try sending it in for service. If its not, either look for a parts camera on eBay, or let me know, I know where to get new OEM lenses for amazing prices.
Good luck from Darntoothysam com
Thomas
Posted on Sep 26, 2008
zohail
  • 1223 Answers
SOURCE: No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on May 05, 2009
SOURCE: SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Posted on Aug 21, 2009
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Dsc-w30 don't work and it always appear access what should will i do?
Lens errors (Access Errors on Sony's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 08, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
Sony DSC T1 - blurry screen and photo
It seems to be the issue with the CCD of the Camera. Until March 31, 2010, Sony will repair, free of charge, the following product models exhibiting the above-mentioned symptom where it is caused by the image sensor device.
Refer the following link:
You can also perform the below troubleshooting steps.
1. Press the reset button with a sharp pointed object when the Camera is turned ON. The Reset button is located near the Control button.
2. You can also power reset the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
Nov 07, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Troubleshooting for my sony cybershot 3.2 megapixels
there is a possibility that the lens assembly is not in the right angle like a piece is not in line, or a possible gear slipage, there are many other reasons why this is happening, you may refer to the pictures below.
question, does the camera give out an error message or when you turn it on and press the zoom, do you hear a sound from the camera itself?
if in case will you turn it one and gently push the kens sideways, because like waht i mentioned, a part may just be stuck.
http://forum.ecoustics.com/bbs/messages/8691/248818.jpg
http://forum.ecoustics.com/bbs/messages/8691/248819.jpg
Aug 19, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony dsc t20
I had to send it back to repair. It was under warranty still so no charges. You should check the warranty they will fix the vibrating problem.
Feb 12, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cybershot DSCP-10
I have a link but for some reason this forum software will not reproduce it correctly. Go to: http://www.google.com Search on: sony dsc p10 add-on zoom lens The link will be at the top of the list. There are lots of add-ons for that camera.
Sep 08, 2005 | Sony Cyber-Shot DSC-P10 Digital Camera
Cameras Logo
438 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
