Question about Sony PlayStation Portable (PSP) Console
Memory card or slot error
I am also having the same problem. Blowing into the slot works for awhile then unable to read memory stick error. Placed same stick into another PSP and it reads fine. Placed it back into the problem PSP nothing. Please help.
  • 140 Answers
Re: Memory card or slot error
If the problem is not the memory stick, then you have a damaged card slot in the psp.
when you insert it on slot, you must make it slowly. if you strongly inserted it, you must have damaged it. or in better cases you have a dirt, faulty contact in slot.
first, look inside the slot, and try to see if the contacts are intact and lined with each other, something like this: | | | | | | | if you see that some of the contact are out of place ( | | | / | | | ), you must take it back in place. the same problem happens with nintendo ds games. if dirt, buy a cleaning kit and clean the contacts.
Posted on Nov 25, 2007
  • 709 Answers
HI Henmoe,
The Memory card slot is to tiny for you to do what Dynomaster is suggesting. I am sorry to tell you that the card slot needs to be replaced. Replacing it yourself will result in damaging the motherboard. It needs to be done by a skilled PSP repair shop.
Click on "Repair Directory" at the bottom of this screen. Select "Video Game consoles" on the next screen. Pick a repair shop that has experince replacing the Memory card slot only. Ask them if they have ever done it before. Good luck dude
0 characters
3 Points
PSP memory card reading problem?
Could be that in the past you would have been pressing the memory stick slot a bit too hard.Give it to the shop for fixing man. No other way.
Jul 14, 2010 | Sony PlayStation Portable (PSP) Console
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
My psp can't read my sony memory stickpro duo, every my psp can't read my sony memory stick pro duo, every time I insert it the light on the LAN showing it in reading process just blink and blink,...
The best way to check if the memory card has the problem or the memory slot is bad is to try a different card and see if the PSP will read it if it reads a different card so the old card is bad but if it wont read a different card the slot is bad and need some repair........
Jan 04, 2010 | Sony PlayStation Portable (PSP) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Try different known good memory sticks and if they don't read any of them, then the slot is bad and since thats connected to the main board, it would need to be replaced.
Jun 16, 2009 | Sony PlayStation Portable (PSP) Console
Psp memory problems
have you tried using your memory stick to other units or computer?
1. if its not working it might be damage.
2. but if its working your memory slot in your psp has the problem then look for a technician that could fix your psp slot for memory stick.
i can see that your memory stick and the psp memory slot is not connecting with each other.. hope it help. for more concerns send as a message
May 21, 2009 | Sony PlayStation Portable (PSP) Slim...
When I put a memory card in slot A it wont work
take the gc apart and look at the memory card slot number 1 it may have ben bent sumhow idk if u have younger bros or sis's they may have tried to put 1 in upside down or summin
Mar 24, 2009 | Nintendo GameCube Console
Memory Card Problem
Perhaps try it on a friends console, if that reads it then transfer data to new card.
May 10, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Memory Card Read Error
Have you tried cleaning the open connections?
Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
Memey stick duo
Try to clean memory stick then clean the slot on the psp
Feb 14, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
119 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
