Question about LG 19" Widescreen Flat Panel LCD Monitor
Monitor no power
Last night while waiting for my download to finish i off my monitor by push monitor power button. When i wake up and on my monitor, the image not appear. Power LED indicate no power.
  • taro7syaz8 Aug 03, 2009
    thanks for reply.i already tried using different cable and power supply but still no power.
  • 724 Answers
Manipulate each ac power cord wiggle it . PS died?
Posted on Aug 01, 2009
  • tommya300
    tommya300 Aug 03, 2009
    Last but not least the power button or an inline fuse of some sort?
    There is nothing else unless the PS you used is bad too?
My monitor is a sleep and wont wake up
Hi Mellissa,
I have the same problem at times.
At the top right hand side of your keyborad there may be a half moon button.(THIS IS A SLEEP MODE BUTTON)
Push that button, wait for your computer power light to turn from blue to yellow.
Then lightly touch the power button on your PC, wait a few then tis should fix your issue, I hope.
Dave
Jan 10, 2011 | Compaq Computers & Internet
Compac keyboard 1/4 moon key on model 5137, once I hit it, monitor went to sleep. I cannot wake it up. I have no password. I have unplugged and replugged entire system, I have tried every combo of keys...
Try holding in the power button on the computer for 30 seconds. wait 5 seconds then tap the power button again once and wait. also check that the monitors cables are securely connected to the computer.
Aug 25, 2010 | Compaq Keyboard
Monitor is flickering and go black severel times before coming.
i feel, you try go to control panel,, and display settings,, from there.. click on screen saver tab, there you can find power button,, click it and change all to never ,, and also dont forget to make screen saver to none.. and see..
Sep 27, 2009 | Samsung SyncMaster 203B LCD Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Waking up monitor
probably ur compuet may be in standby so u have to beat the keyboard to wake it up .
Dec 05, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
LG 19" Widescreen Flat Panel LCD Monitor Logo
158 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
