Question about Samsung SPN4235 42 in. Plasma HDTV
Samsung SPN4235 fails to turn on..led blinks five times
I have an Samsung SPN4235 that fails to turn on...led blinks five times. I have replaced several parts in the set so far and get the same result. Seems like the logic board is bad because when I unplug it from the power supply board I get voltage at the majority of the test points on the power supply board. I swapped out the logic board but the same problem occurred when I plugged the new board into the power supply board. I'm at the point now where I'm not sure what to do next. Any help would be appreciated.
  • 6 more comments
  • Arlen Aug 01, 2009
    No, I haven't tried running the set with the Y buffers out since the set won't even come on. Seems to be in some type of fault protection mode. Anyway, the only way I can get voltage at VA, VS, VE, etc. is to unplug the logic board which is listed as CN803.
  • Arlen Aug 02, 2009
    I have already went through the unplugging each connector scenario to figure out which board has the problem. That's how I figured out that the voltages show up when the logic board is unplugged. The problem now is that I replaced the logic board and the problem is still the same. Is there anything else you can recommend to me?
    Can anyone else please give me some other recommendations about which direction to go with my problem? Everything I have done so far is listed above this comment.
    Thanks
    Good news is this is just a set I picked up and wanted to see if I could fix it.
    Thanks
    Looking at my previous comments can anyone say for a fact that it's probably not the power supply board?
    So far about 20 capacitors and one IC on the power supply board. I don't think any of the parts were defective though. The logic board was also replaced. I also re-flowed all the solder joints on the power supply board.
    Anyone else?
  • Arlen Aug 05, 2009
    It did end up being a bad power supply.
  • 11,896 Answers
Replace the power supply
Posted on Aug 02, 2009
    Sergeant:
    Champion:
  • 257 Answers
Have you measure the power on voltage from the main board. The problem could come from main board so it would not give correct order. Try to get power supply stands alone (unplug all loads) except the main board, then measure the Vs on when the set turn on. If this is OK, you could then re-plug each related board one and measure each time and see if there is any voltage drop causes by a shorted board.
For the Y board- you have to swap with the new Y main + buffers to avoid buffers got shorted and kill the Y-board (it happened to me). Do not forget X-board, it hard to fail but it happens.
You can use your eye to exmine those silicon glue on the IC on the buffers, if it look brownish or dark yellowish, the board has been shorted. If you need service manual, let me know, I could find it for you. Good luck
Posted on Aug 18, 2009
    President:
  • Samsung Master
  • 1,314 Answers
What parts have you replaced? Have you tried the power supply board?
    Genius:
  • 1,689 Answers
Hi arlenj,
looking at the previous comments and the complexity of the problem. i just want to be honest that this may be a good time to get a new HDTV.
no need to accept or reject this answer, im just giving an honest opinion, not an answer.
regards pal,
voodoo
    President:
  • Samsung Master
  • 2,923 Answers
The panel could be shot, or it could be a pcb inside, such as L-main, Main, or Y-main, if you open it up and check all the panel voltages you could find the board with the problem by unplugging a board at a time and then seeinfg if the voltages come up, the voltages are on a sticker and the test points and pots to set them are on the power supply board and the DC-DC board. Hope this helps and have a great evening!
My compaq 615 does not boot, it just turns caps' light on five times and then nothing happens
What you are seeing is a "blink code". Similar to something like a digital SOS message, your laptop is built to flash certain LED lights a specific number times to indicate a hardware problem.
According to Compaq's table of blink codes, the Caps Lock LED light blinking five times consecutively means you have a system board failure. If your laptop is still under warranty, I would contact the company immediately and have it shipped out to be serviced. Otherwise, you will need to either pay Compaq or another third-party repair shop to fix or, more likely, replace the system board.
Mar 01, 2011 | Compaq Computers & Internet
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
5 blinking red lights when turned on
When you remove the bad check for bulged electrolytic caps, that need change, or change out the power supply.
Oct 18, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Samsung spn4235 need power supply
You can order the original Samsung replacement Power Supply Board for this model (SPN4235) from a major Samsung parts distributor at the link below:
Samsung SPN4235 Replacement Part SMPS Switch Mode Power Supply Board
Apr 08, 2009 | Samsung SPN4235 42 in. Plasma HDTV
SPN4235 TV -- red light blinks but picture doesnt come on.
being that it fell , this is already a bad sign that the screen is dammaged and it will need to be tested and looked at to see what other dammage has happen to it
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
My Samsung SPN4235 42 in. HDTV
you could to go to samsung website to call the customer support to get an authorized repairman to fix it for you,unless it is still under warranty which you should take it back to the retail store you got it from.
solutiondoct
Jul 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung SPN4235 42" Plasma
green light flashing no video but audio, on/off switch in operable
Nov 12, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Samsung SPN4235 42 in. Plasma HDTV Logo
1,318 people viewed this question
Henry  Thomas
Henry Thomas
