Question about Canon Office Equipment & Supplies
Error code 5100 and belt that moves ink cartridge is making noise.
    President:
  • 1,197 Answers
Hi there....
since u dint specify ur printer model.... iam giving u a generic reset procedure..... first try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
5100 is a Carriage Home Position Error. if the above reset procedure dint help....
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
if even after cleaning the strip ur experiencing the problem then u can be rest assured that its time to call canon...
thank you for using Fixya...
have a nice day
Please rate this solution.
iversh
Posted on Aug 01, 2009
I have an error 5100. What do I do?
Error 5100 is a cartridge jam , you will need to remove the ink cartridges and reinsert them into the printer and make sure nothing is blocking for the cartridges to move better if you can blow a compressed air to it to make sure all small piece of paper that can cause these error will be remove.
Jul 12, 2011 | Canon PIXMA MP470 All-in-One Printer
When changing an ink cartridge on my i9900, the cartridge carrier suddenly began to move. Because the cartridge was only 1/2 half way out, the carrier got stuck for a second or so at the side of the slide...
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Jan 28, 2011 | Canon i9900 InkJet Photo Printer
HI I HAVE A CANON MX 320 MULTIFUCTION MACHINE, THE INK CARTRIDGES HAVE BEEN REPLACED BUT THE SCREEN KEEPS SAYING PRINTER ERROR HAS OCCURED 5100, HAT DO I DO TO FIX
5100 error means a Carriage Home Position Error.
Just make sure you remove the plastic strip covering the print head and the contact copper of the ink cartridge before you insert it to the cartridge holder.
Other possible solutions is that the cartridge is not properly seated on the carriage or cartridge holder. Once it is not properly seated the cover of the cartridge holder usually hit when it moves.
You may also clean the contact copper of the ink cartridge using an soft cloth or cotton moistened with alcohol to clean the surface. Please avoid touching the surface by your fingers.
Jun 23, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Error 5100
Jun 29, 2009 | Canon MX300 Office All-In-One Printer
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
there is ahook that sits on the leftside and a spring it sits on to give it some lleadway check to see that it doesnt break, there is also a section of the carriage it slip thru i also try to get it re attached.
Jun 09, 2008 | Office Equipment & Supplies
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Nov 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
241 people viewed this question
old marine
old marine
