Question about Q-Logic QLE4060C-CK Network Adapter
A/c compressor cluch comes on & off more often tan normal?
  • 11,896 Answers
Clutch may be faulty or sticking.
Posted on Aug 01, 2009
Ice cubes & frozen food thawed out, food in refrig not cold. Compressor runs for 20-25 second and clicks off, after 1-2 min comes back on. The a/c amps reads 8.5 wht wire and 9.5 on red wire to the...
You are cycling on the compressor overload, meaning the compressor is drawing excessive amperage, the overload takes it out then it cools down and tries again. the normal amp draw for those compressors is 3-4 amps. Have you checked the condenser fan and made sure the coil is clean?
unfortunately those compressors cannot be serviced
Jun 27, 2011 | Kenmore Side by Side Refrigerator
1996 grand am air compressor will not engage has correct amount of 134a but cluch does not grab even has new cluch, is there a low pressure switch i have trace the low pres-line and can not find a sensor...
Hello: Check all the fuses for the system, make sure the connector to the clutch coil is fastened correctly. Check the back of the a/c compressor and the accumulator for the switch.
Jun 01, 2011 | GMC Blazer Cars & Trucks
My daughter bought a master airbrush spray tanning system - g70 - with no instruction manual. air is coming out but no tanning solution - any assistance would be greatly appreciated
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
Jan 16, 2011 | Master Heaters Master Airbrush Model G75...
Cracked radiator & cluch problems
No warranty on any cooling system parts.You might want to have the radiator checked for blockages in the cores,That would build up the pressure on the plastic side they use on radiators now.Clutch is normal wear
Dec 14, 2009 | 2004 Pontiac GTO
Ac cluch making noise when ac off
yes however it is very diffucult without the proper tools. Suggest checking with an auto parts house where they may be able to assist you on the replacement. Good Luck
Dave
Oct 12, 2009 | Heating & Cooling
Sin,cos,tan answers arent coming out right. They are off by a couple of numbers Ex: tan 36.7 enter 7 divided by 60 then add 36 and i get .729658205 instead of .74537703
What you deplore is perfectly normal.
7/60= 0.1166666667 the last 6 has been rounded to 7 (result is periodic)
36 + 7/60= 36.1166666667
36.7 -36-7/60=0.8166666667
tan(36 + 7/60) = 0.7296582051
Compare the tangents of two close numbers
tan(36.7)= 0.7453770282
tan(36.66666667)=0.7444724166
True, the precision of calculator is limited, but the number of digits it can display has a lot more precision that real-life problems really require.
Hope it helps.
Oct 02, 2009 | Texas Instruments TI-30XA Calculator
1996 toyota celica ac not blowing cold. freon is fully charged & ac compressor cluch is on but just warm air comes out the vents
The flap that directs cold air and warm air may be stuck in warm air position. This flap is controlled by a vacuum operated actuator that is attached to the vacuum lines and the control panel. This can go bad. Otherwise check in compressor sight glass to make sure there is no air bubbles or fog, that would indicate a leak in the system
Sep 25, 2009 | 1996 Toyota Celica
99 dodge grand caravan a/c not working.compressor cluch working,fans don't come on lines hot down at compressor
Cooling fans must work with a/c on.With a/c turned on check voltage at fan motor plug.If no voltage have to back trace to fuse for fans or relay's,but I have replaced a few fan module's for this problem.
Aug 19, 2009 | 1999 Dodge Grand Caravan
My Envoy stalls when A/C compressor comes on when A/C is turned off it idles fine can you help?
It sounds as if your compressor has locked up. When the compreessor is off the clutch disengages it, when it turns back on the cluch locks up because the compressor is locked up.
Jul 02, 2009 | 2002 GMC Envoy
Q-Logic QLE4060C-CK Network Adapter Logo
49 people viewed this question
Top Q-Logic Computers & Internet Experts
David Payne
David Payne
Are you a Q-Logic Computer and Internet Expert? Answer questions, earn points and help others
