Question about Midland 20-Mile, 22-Channel FRS/GMRS 2-Way Radios with Charger (Pair)
How do I deactivate the RX feature on this radio? Too much static.
    Scholar:
  • 146 Answers
What you want to do is tighten up the squelch adjustment and that should reduce the white noise you are hearing. also keep them away from any computers, the square waves generated by them will open up your squelch annoyingly as well.
Posted on Sep 16, 2009
One of 2 set Motorola MH230R isn't transmuting ring or voice, but receiving is fine. All settings the same. What's I am missing?
Check your batteries. Transmitting (Tx) takes more power than Receiving (Rx). Also, check to see if you have the Qt filter turned on, if so, turn it and all other special features off (zero) and try using the radios in a very basic mode. If you cannot Tx or Rx with good batteries, and all special features turned off, you have a problem with one of the radios.
Sep 26, 2015 | Motorola MH230R Two Way Radio
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
I have a dx 929 everytime i go under powerlines it gets a ton of static very fast
the export style of radios have a wide band rx filter. not like the cobras and unidens. so they will pickup more static. just by design.
Dec 07, 2010 | Galaxy Radios DX-929 40-Channels Base CB...
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
GMR1035-2
The RX symbol and static noise would only appear if the squelch is down or if you are receiving something from a transmitter.
Receiving something could mean either an intelligent radio transmission from another comparable unit or this could also be spillover signals from adjacent radio transmitters strong enough to override the squelch settings normally called "splatter". At times, electronic devices could cause this effect such as RFI (radio frequency interference) from units such as a personal computer.
It is also possible that your Monitor Mode is "ON", turning it OFF would possibly resolve the issue To turn OFF monitor mode:Press the vol/mon UP or DOWN key. The RX icon will stop blinking and disappears.
In some cases, a component failure would cause this problem. Your GMR1035-2 uses an Automatic Squelch Feature, this would mean the use of a FM Discriminator Chip for Squelch Control. Most manufacturers uses an MC3357P IC chip for this purpose. This of course would require opening the unit, desoldering the suspected component and solder in a replacement. This would further require that you be familiar with electronic components, circuitry, DVM and a low wattage soldering iron. Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 10, 2007 | Radio Communications
Midland 20-Mile, 22-Channel FRS/GMRS 2-Way Radios with Charger (Pair) Logo
475 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
