T.V. is giving a message that it will shut down after a few seconds and to check the air flow?
  • April Neace Aug 01, 2009
    Thanks for the suggestions. We purchased our T.V. at Circuit City and tried to call the warranty people before the warranty expired and the number was disconnected so we are stuck with the charges.
  • 11,896 Answers
Processor is getting overheated. Your inside of tv is getting very dusty and needs to be cleaned out.
Posted on Aug 01, 2009
    Brigadier General:
  • 4,090 Answers
Possibly the fan to the cooling light has failed. needs a callout tech before it overheats and causes more problems
My isuzu Ascender is giving me problems every time I try to fill the gas tank It shuts down every second so it gives you a hard time to put gas in
there is a problem with the air trying to get out as the fuel is being pumped in . This activates the shut of in the nozzle of the hose . Try holding the trigger just open so that you control the amount of fuel flowing in . Try rotating the nozzle in the filler a few degrees so that the fuel coming back will no activate the shut of system. I have found some pump systems are extremely sensitive to the air/ fuel flow back so I am selective in which pumps I pull up at for this reason. Remember you do no have to pull the trigger full bore when filling as you can control the setting with your fingers.
Dec 14, 2013 | Cars & Trucks
Fan blows, gas flows, ignitor lights, gas burns only for a few seconds then kicks off, repeats a few times then shuts down
Check the circuit for the draft inducer fan motor. The centrifugal switch in the motor may be shutting down. This stops power to the gas valve.
Nov 20, 2009 | Goodman Heating & Cooling
Error / problem message
these are on mitsubishi's recall list you need to get in touch with mitsubishi and have them find a authorized servicer in your area to come put a thermal sensor in your set.
Aug 12, 2009 | Mitsubishi WD-57732 Projection Television
Air flow blocked message appears when turning on
Replacing the thermal sensor is the cure for this. If you call Mitsubishi at 1-800-332-2119, press 5 for Customer Service. Explain the problem and they will probably approve a extended warranty claim and get the repair done for free through a Mitsubishi Auth. Repair Facility. They will also help get you in touch with one near you. Do not delay in acting on this. I do not know how long the extended warranty claims for this problem will last.
Hope this helps,
Skyassoc
Jun 20, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Apr 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Problem installing kd-sx840
OK Buddy. You came to the right place. Give me year/make/model of vehicle and I'll hook you up :-)
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 24, 2009 | JVC KD-SX840 CD Player
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
