Question about Frigidaire FRS23R4A Side by Side Refrigerator
My side by side frigidare is barely blowing air and its not cold at all. what could it be?
  • Frigidaire Master
  • 4,655 Answers
Your problem most likely is the Adaptive defrost timer . Click here if you need one CLICK HERE=> Part Number 240554502 Adaptive Defrost Board
The next most likely reasons for this is a burned out defrost heater part number CLICK HERE=> PART NUMBER 5303918255 DEFROST HEATER KIT
Or the defrost thermostat and fan motor. All in that order. Let me know if this is helpful and please rate me. Thanks Sea Breeze
Posted on Aug 01, 2009
  • John Tripp
    John Tripp Aug 01, 2009
    If you have questions please feel free to let me know, Thanks Again, Sea Breeze
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
My frigidare wall mount air conditioner won't blow cold air? Can this be fixed?
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN><o:p>&nbsp;</o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Here is a tip about troubleshooting your air conditioner...<o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>There are many things that can cause your air conditioner not to cool…<BR><BR><A href="http://www.fixya.com/support/t4975332-c_run_only_humming_noise_when_turned" target=_blank><FONT color=#0033cc>Air Conditioner</FONT></A> Trouble -Review the <A href="http://www.fixya.com/support/t5003406-compressor_failure_sends_out_hot_air" target=_blank><FONT color=#0033cc>Possibilities</FONT></A> <BR><A href="http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi</FONT></A><BR><BR>heatman101 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></SPAN></P>
Aug 25, 2010 | Frigidaire Heating & Cooling
Refrigerator side is not cold
Sounds like a problem with the damper control. Some fridges gets humid air causing frost on the damper and causing this to fail. It may need to be replaced or check if the damper (the vent were the cold air comes out from the freezer) is open.
Jun 07, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
'95 325i vert-cold a/c but low air volume
check that the cabin filter is not blocked https://www.youtube.com/watch?v=UjSnUgC4cWI
Feb 05, 2018 | 1994 BMW 3 Series
2006 Jeep Grand Cherokee Laredo ac not cooling
My 1999 limited does this. When i bought it off the guy he said that its because of some flap down by the passengers left foot. In mine the passenger air barely even blows because of this.
Jun 17, 2009 | 1999 Jeep Grand Cherokee
Fridge not blowing cold, Buzzing inside black ball "compressor"
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
May 17, 2009 | Frigidaire FRS23R4A Side by Side...
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
I have a 1999 Dodge Ram 1500 the air blows out ice cold for about 20 min. and then just shuts off what would cause this I put a gauge in the vent and it was blowing out 38 degrees
I have a 1996 Dodge Ram 1500 club cab. I have had my a/c recharged but it is only blowing barely cold air. It used to shut down when I accelerated and blow hot air before. I don't have that problem anymore except barely cold air. Any solutions?
Jul 26, 2008 | 1996 Dodge Ram 1500 Club Cab
Frigidaire FRS23R4A Side by Side Refrigerator Logo
199 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
