Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
Inside Dsiplay Not Always on
The inside display that shows the temperature does is not always on. The fridge seems to be cooling and the inside lights come on - but only sometimes does the temperature display show.
  • Anonymous Dec 29, 2008
    Same this is happening on my 3-year old fridge. Sometimes when I open the door, the refrigerator and freezer temp displays are not on. Otherwise, things seem to be working well, but I'm concerned the thermostat is going to fail soon. This problem only recently started to occur (after 3 years.)
  • 447 Answers
Most likely it is the Main Control Board also called the Motherboard. It is located on the rear of the unit behind the smaller axcess panel. Becareful with the wiring if you attempt to change the board. There is a slight possibilty that it is the dispay board, but it is unlikely.
Posted on Nov 25, 2007
Blue Star 1.5 ton 5 star inverter split AC remote "TEMP" button seems not functioning. does any one help me? how to check this function as always remote is showing set temperature.
does that on mine as well
the temp is what is on the inside wall unit when turned on the remote reads 25 and the inside unit reads 30 but eventually comes down to 25
Apr 14, 2017 | Star Heating & Cooling
Samsung RS253BASB SidebySide Fridge Not being Cooled
Probably bad fridge tstat sensing bulb (tstat)
possibly bad open heater in area of fresh vegetable bin
or damper assy not set correctly
Dec 08, 2007 | Samsung RS2534 Side by Side Refrigerator
Beko CDA543 F freezer always on?
noise sound like compressor mount are loose or rubber garment fell off that stops vibration or pump is bad internally call warranty get replaced if not a mounting problem of compressor
Mar 02, 2017 | Freezers
My F&P fridge (F/E372BRT) recently gave out a loud alarm recently, which i stopped by pressing one of the temperature control buttons inside the fridge. However the green lights now flash inside the...
It is best to consult your users manual first as controls are like humans nowadays. They are all different in programming features.
You may have set it for an illogical temperature or a component malfunction may have occurred and the alarms alerted you to that with an error code display. No error code =no malfunction and more than likely means a human error was made.
Oct 15, 2017 | Fisher and Paykel Refrigerators
Our fridge temperature control is not working. its always high and all the things we keep inside gets spoiled like leaves and vegetables. pls help
Please get the thermostat switch/temperature control switch replaced by a Samsung technician. Also check the cooling gas. If it is less then no proper cooling will be done. This could be the possible cause.
Jan 04, 2011 | Samsung Refrigerators
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
264 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
