If it is a Keypad Unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that. Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
You can't post conmments that contain an email address.
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Make sure that the keys are actually locked. If you
attempt to unlock a keypad that is not locked, nothing will happen. Look
on the phone's screen for the key icon that indicates the keypad is
locked. If you try to press any of the keys and the word "Unlock"
appears on the screen, your keypad is definitely locked. If you do not
see the indicator but are unable to use the keypad of your Nokia 6085,
your battery could be dead, so try recharging it and then see if the
keypad works.
Enter the unlock sequence. If the key indicator
appears on your screen, you need to enter a simple sequence of keys to
get the keypad working again. For the Nokia 6085, select Unlock and then
quickly press the * key. If you wait more than 1.5 seconds to press the
* key after selecting Unlock, it will not unfreeze the keys so make
sure you enter the sequence very quickly.
Turn off the automatic keyguard. If you are tired of
having to unfreeze the keys every time you want to make a call, you can
program the Nokia 6085 to always remain unlocked. In the menu, go to
Settings, then select Phone, then select Automatic Keyguard and choose
Off.
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing the Power button you are prompted to choose either "Off" (Left Soft Key) to power off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad, select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Samsung phones have special unlock codes which can be used to unlock the phone when keypad lock code cannot be found. But first it is advicable to try the factory code which usually is 00000 if this does not work then try Master reset(unlock) #*7337#. Hope this solution has been helpful?
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad?
To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK
button. You can set your phone to lock the keypad immediately, or
automatically if no key is pressed after 30 seconds, 1 minute, or 5
minutes.
