A belt melting usually means it is stretched out and so loose it is slipping on the brushroll or something is restricting the brushroll from turning freely.
The brush being melted by the belt could be caused by something restricting the brush from spinning freely. Clean under the endcaps and check the bearings of the brush roll.
That means you had too much hair in your beaterbar or that you had the vacuum set too low to the floor. The beaterbar stopped turning and the rubber belt was slipping creating friction and heating to the point of melting. When you vacuum check often that the powerhead (beaterbar) is moving. If the belt ever slips it stretches or melts in half and must be replaced. If you were referring to the motor then there isn't much you can do but replace the motor.
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
