The cable (20amp) at the back of my oven melted. At first I thought it was badly installed so I had a new wire installed. It's working again but I think the outside of the oven is too hot on the outside. What's the maximum temperature should it be, i.e. how hot is too hot?
SOURCE: oven overheating
I have just purchased a new thermostat and installed it. The oven now works fine and the heat light cut in and out showing temperature is being controlled.
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
SOURCE: fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
SOURCE: Natural Gas, convection oven won't heat.
If the gas valve is on(no continuity) then yeah that is it, keep in mind the ignitor could be weak. I didn't notice where you replaced the ignitor and you say it is working so that means the gas valve has continuity. You need 37 ohms on that ignitor or a total amp draw of at least 3.5 to open that valve.I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thank you for the info, very helpful."
