Question about Samsung ML-2240 Laser Printer
CAN"T PRINT THERMISTOR OPEN. RECYCLE POWER. WHAT THIS MEAN. HOW TO SOLVE THE PROBLEM
  • 724 Answers
Over heating sensor where is it located? in the Drum may be change it out?
Posted on Aug 01, 2009
How to solve the km 6030 machine error code c7200
Hi Farid,
Error Code c7200 means : Broken internal thermistor wire • The thermistor output value is 4.5 V or more.
Because of : Poor contact in the connector terminals. Defective developing humidity sensor.Defective engine PWB.
Need to replace the defected part. please visit to the nearest service center.
Thanks
Aug 18, 2015 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Error display hc551 for Ricoh Aficio MP1600le, pl help me how it solve the problem.
Error code: 551 - Fusing thermistor open (rear)
The fusing temperature detected by the thermistor is below 71C and is not corrected after the main power switch is turned on.
Causes:
- Fusing thermistor defective or out of position
- Power supply board defective
- Loose connectors
Apr 29, 2015 | Ricoh Office Equipment & Supplies
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Message on machine states error 77, unplug and call brother?
Error 77 basically means- Heater thermistor short circuit. However, the message is sometimes incorrectly shown. You can try this- power off the machine, take out the cartridge, close the door and power up. The machine should notice either the toner or the front door is not in place. Now open the door and place the toner. This might solve the problem. You can also try to soft reset the printer. If none of these works, you might have to change the thermistor.
Apr 06, 2010 | Brother MFC 9700 All-In-One Laser Printer
H 4 blinking code
# interrupt>C>interrupt>press 14>print key
Dec 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
When i tried to print show me the message termistor open
A thermistor is a small temperature sensor that the printer has inside. It probably uses it to read the temperature of the fuser. The printer may have more than one thermistor. The message that it's open means that the printer cannot get any electricity to pass through the component at all. You may be able to replace the thermistor itself or by replacing the whole fuser assembly, but you may need someone to fix it for you.
Oct 13, 2009 | Samsung ML-2240 Laser Printer
EPSON DFX-9000 ERROR CODE = OD and OB
error code OB turn off the printer, why?
Sep 17, 2008 | Epson DFX-9000 Matrix Printer
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Samsung ML-2240 Laser Printer Logo
475 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
