Question about Cameras
The usb will not transport pictures anymore
The camera works perfectly. The only problem is im unable to transfer pictures from the camera to the computer. And i know it not the computer because other cameras work on it. The yellow and white ports work tho.
  • 11,896 Answers
Download the latest drivers for your camera.
Posted on Aug 01, 2009
How can I transfer pictures to the computer?
Two easy ways - one is to connect your camera to the USB port on your computer with the appropriate lead, at which point Windows (tm) will recognise it as a satellite drive and you can copy the images across to any folder of your choice. The other is to remove the memory card from the camera and use a card reader to transfer the images.
Mar 29, 2016 | Cameras
How to view pictures off ch-ez splash digital camera
Be aware your camera expects a 5 Volt on the usb cable, for charging, unless a computer gives a signal that is connected to transfer pictures. Then the computer will "tell" the camera how to transport the pictures. So don't expect your camera to become a unintelligent USB memory stick.
Jan 05, 2015 | CHE-EZ Splash Digital Camera
I CANT UPLOAD MY PICTURES ANYMORE
Get a USB memory card reader for your style of memory card and use that to transfer the photos to your computer. That works better and is faster than connecting the camera which also requires the correct camera software to be installed onto your computer first. Avoid that with an inexpensive USB memory card reader.
Sep 13, 2009 | Polaroid PDC 3080 Digital Camera
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Can't transfer pictures to computer
First start easy share program, than turn on camera, then plug in to usb
Jul 01, 2009 | Kodak EasyShare C340 Digital Camera
Pictures transfer dark unable to view
I don't think it is the cable. You should be able to adjust the lighting or auot-fix with you viewer. Such as windows picture viewer, kodak easy share program.
Jan 17, 2009 | Nikon Coolpix 5700 Digital Camera
Suddenly unable to transfer photos into Nikon Picture Perfect
How are you transferring the photos? Are you using a cable, or a card reader? If you are using a cable then most likely the cable went bad. I have a D-1 and a D-2, and I never use the firewire cable. I put the CF cards into a card reader. If you are not using a card reader then try that. You can get a decent one from E-Film or from most any computer store.
One more step to try, did you format the card in the camera when you first loaded the card in? On my cameras you need to format that card to have them work with the camera.
Dec 16, 2008 | Nikon D40x Digital Camera
I cant upload my pictures to a mac computer
see first urs usb cabel is well fitted in urs pc or not or wid camera.....
if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader...... but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not....
ask me if it creates more problem.....
thanks...
Jun 29, 2008 | Samsung Digimax S500 Digital Camera
Transferring pictures from digital camera to computer
if you have a sony digital like mine my pc pick up new hardware
and you get guided thru download process it is as easy as pie
Nov 13, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Cameras Logo
43 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
