Question about Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
Had PS3 connected via HDMI and it worked fine. Moved PS3 to another shelf (so unplugged and plugged back in) and got weird cascading white/pink visual static or blank and no sound.
Tried a second HDMI cable, no joy.
Tried the AV cable but no joy. Didn't realize I have to reset the PS3 to use the AV out so will try that next.
  • dalekarenm Aug 01, 2009
    Reset the PS3 and it works fine via the AV cable.
    So it's down to HDMI but I still don't know if it's the PS3 or the TV.
    I don't have any other HDMI components to try on the TV..
  • dalekarenm Aug 06, 2009
    I made sure to turn the PS3 off before unplugging and moving.
    I took the PS3 to another tv with HDMI and it worked. So now I'm pretty sure it's the first tv HDMI input.
    When I look closely at the HDMI input on the tv, it kind of looks like the connector is damaged a little bit.
    Now I'm wondering if I can repair that without sending the whole tv away...
If your ps3 is working with the HDMI cable and not with the AV output cable and you want to use your old tv that only has av you must first turn the ps3 on using a tv with hdmi input and go into settings and restore the system to default settings and it should automatically restart. (when i did this, i quickly turned the ps3 off after the restard and plugged in the av cable so it would first start the system with av cables, not sure what will happen if you leave the hdmi cable in, i assume will leave you in the same problem as in the beginning) hope this helps.
Posted on Sep 28, 2009
  • 123 Answers
Did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Posted on Aug 01, 2009
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
1,209 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
