Question about Homelite Mighty Lite Lawn Trimmer
How do you take off the clutch to get the string on a Ryobi SS30.
  • 154 Answers
There are 2 slats to push in to remove, i have same one
Posted on Aug 01, 2009
    Problem Solver:
  • 5 Answers
1-Remove the plastic handle with the four torx (t25 or t27)screws, pull on the handle to separate it from the engine. (I left the throttle attached and pushed the handle to the side to keep it out of the way)
2-Remove the spark plug and stuff several inches of clean nylon rope down the hole to lock the engine in place. Dont forget to leave plenty hanging out
3-Loosen the torx screw (same size as handle screws) from the center shaft of the drum and connector. The screw will not come out of shaft. Counter clockwise to loosen.
4-Remove the drum and connector by gently prying straight out. The drum is very thin and open on the back so make sure you only pry on the drum and not the clutches underneath it.
5-grab a stiff beverage and/or cigarette to releave the upcoming stress!
6-Ok, its really not that bad, just a bit tedious. The clutch plates are removed by taping them counter clockwise (lefty loosey). Dont second guess it, they really do come off counter clockwise! I used a chisel and a dead blow hammer to get them to break loose, then they just spin right off. Be sure to start with the top clutch, and try not to hit the plates too far out on the ends of the s arms, as they will bend quite easily. If you ruin the clutches, the part # is 00242, if your lucky you may find them at a local homelite/ryobi service center for around $8.00 each.
I'm sorry but this is about as far as I can help as I havent needed to replace the pull cord on this trimmer yet. I never could find any clear/definitive info on the clutch removal so thats what I was hoping to provide here. Good Luck!
Posted on Oct 03, 2009
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
Manual for ss30 string trimmer
http://dl.owneriq.net/9/9e64612c-7e9e-49b8-b7af-195ff11f1bef.pdf
Jul 02, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
The pull string coil came loose cant figure out how to get the piece that connects to the shaft off on the ryobi ss30 weedeater
There is a cover that you loosen you pull back the handle then youll see a clamp I think its 5/16 loosen it will move but there is a thottle cable you have to loose off the thottle on thr carberator then it will slide off ,if it is a clutch ,the clutch has to be removed by the way of the the arrow then you can get to the rewind
Nov 04, 2009 | Ryobi Garden
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
677 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
