Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
No drivers found
My wd 500 bg book: lights bright, sounds quiet like was working, cable usb works(tested)but not appears in the drives, but last week was working perfect. try to add a new device but not drivers found
  • 696 Answers
If the lights are lit and you can hear the drive spin up power is likely fine, you state you tested the USB cable so we'll assume that's fine. This leaves two large possibilities left, first the drive circuitry may have failed. If this is the case you should still see the USB Mass Storage Controller in your Device Manager. This will mean you need professonial assistance recovering you files.
If the USB Mass Storage doesn't show up in device manager you may be in luck and it may be the USB circuitry that has failed. If this is the case, pop into any reputable PC shop and have the techs move the harddrive into a new enclosure to test it. If it works there, buy the new enclosure and you're on your way. If it doesn't again you will likely need a recovery pro.
If you need a recovery pro, reply back here by adding a comment including your Country, State and City and I will refer a nearby Pro who can assist you further.
Hope this helps FixYa,
Chris
Posted on Aug 01, 2009
I have a WD 1.5 TB My book 3.0. I have it for a couple of weeks, but now all of the sudden the PC(s) doesn't recognize the device anymore. Device manager does display the right hardware, and says it...
Try this. Download a program called discovery from WD, it is free. When installed, plug in the drive and run the discovery program. Your drive should work properly. Please let me know how it works for you.
Sep 19, 2011 | Western Digital My Book Essential Edition...
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
I have WD My Book Essential 2 capacity 500 GB. Unfortunately everytime I connect it to the PC and power, does not show as a hard drive and has no driver. I backed up my files on it from the same computer...
you may have a bad drive,but first dose the drive power up not just light up can you hear the drive.
what you have in the box is just a nornal HD in an external box. you can if "absolutely nessesary " remove the HD and put it into your PC as a second drive.
but first you need to know if it is running and if the WD My Book power supple is working.
Have you tried using a different USB cable? a different power supply of the same Voltage & amps.
Mar 25, 2011 | Western Digital My Book Essential Edition...
My computer does not see it
There are a few reasons this would happen, The options are a bad USB cable, a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians test it with a new USB cable, if it works buy the new cable. If that also fails to work have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Chris
Nov 03, 2009 | Western Digital My Book Essential Edition...
WD hard drive not recongnize by laptop!
Do ypu have another computer you can test it on? Plug it into via your USB port.
Jul 12, 2009 | Western Digital My Book Essential Edition...
WD My Book Essential -- Can't find drivers
It should not really need drivers in Win2K or Vista, you might have a problem with your USB drivers. Go into device manager, remove any devices under the USB heading and reboot. All the drivers should reinstall and hopefully your MyBook will come alive again. Otherwise, try the MyBook on a friend's computer, if it doesn't work there then the MyBook may be faulty itself.
Jan 15, 2008 | Western Digital My Book Essential Edition...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Found usb device message
There are drivers available for your book on the WD website...They are meant to be used with win98...If you're using XP the drivers it's asking for isn't for the book but probably the USB hub...
Things you could do by order of priority:
1) Re-install the driver for USB hub
2) Install those 98 drivers (won't do any harm)
2) Repair Win XP
3) Re- format your PC (I know it's extreme...but as a last resort you may want to consider it)
Good luck !
Nov 18, 2007 | Western Digital My Book Essential Edition...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
297 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
