Question about Navigator Evesham Nav-Cam 7000 GPS Receiver
Maps my brother has deleted all the maps and all the other on the sd card is there any way you can get that information back on the card.please help.
  • speegt Sep 27, 2009
    hi do you have the cd with the maps of the us on it , i recentl got this navcam 7000 no d card , i have a card but need the maps where can i get them
I have a nav cam 7000.
is there a download or site I could go to, to enter,to change the postcode to 7 letters, instead of 5 @numbers.as at present, to navigate to an area.ernie
Posted on Nov 06, 2009
It should all be on the accompaning CD. If this is not available I have the CD. The data is about 98-99MB insize.
Posted on Aug 15, 2009
    Brigadier General:
  • 4,090 Answers
NO. Not unless you pay for a new set of maps. Also the maps are unique to the Sd card so pirating them will be of no help
Posted on Aug 01, 2009
Hi i have a 7700 nav cam need to up date is there any way to get update
Posted on Nov 26, 2009
How to recover deleted Sony photos?
There are sd card data recovery software packages available that will recover lost data. Google "sd card data recovery" and you'll see many to choose from
Nov 19, 2014 | Sony Cameras
I want to delete maps from my Garmin Nuvi 1450 LMT to make room for different country maps. How would I do this? I have been looking for answers online and in manual for hours now with no luck. Please...
    • 1 Remove the SD card from the Garmin GPS.
    • 2 Insert SD card into your computer's card reader.
    • 3 Open the "My Computer" in either the desktop or the start button.
    • 4 Double click the SD card folder to open it.
    • 5 Hold "Ctrl" on your keyboard and left click on all the map files in the folder. Once they are all highlighted, right click and select "Copy."
    • 6 Go to your desktop, right click and select "Paste." You have created backup copies of the maps in your Garmin GPS. Return to the SD card folder via "My Computer."
    • 7 Select the map file you wish to delete, left click it once and press both "Shift" and "Delete" on your keyboard.
    • 8 Return the SD card into Garmin GPS. Turn it on. Check the screen to see if the right map has been deleted. If any mistakes are made, simply start over from step 1. Replace any map that has been accidentally deleted.
    • OR Insert one end of the USB cable into the USB port on the Garmin. Insert the other end of the cable into the USB port on the computer.
    • 2 Click on the desktop "Start" menu, and chose the "Computer" folder.
  1. 3 Right-click on the Garmin drive folder, and select "Open." Some Garmin GPS devices (e.g., Nuvi 200 through 800 series devices) will have the map files stored here. Browse this folder for maps you want to remove, right-click on the file and select "Delete." If no map files are available, go to step 4.
  • 4 Double-click to open the "Map" folder.
  • 5 Right-click on any map file that you want to remove, and select "Delete."
  • Sep 18, 2011 | Garmin Nuvi 1450LMT
    I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
    The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
    1) Remove the SD card from the memory slot
    2) Connect the nuvi to the computer via USB cable.
    3) Open the nuvi drive.
    4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
    5) Empty the Recycle Bin.
    6) Retry the map update of the nuvi.
    This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
    1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
    2) Disconnect the nuvi from the computer.
    3) Connect a card reader to the computer.
    4) Insert the SD or SDHC card into the reader.
    5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
    6) Update the map to the SD or SDHC card.
    When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
    I hope this helps & good luck! Please rate my reply - thanks.
    Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
    Need a fully working Lowrance 250C GPS SD card or a copy of the same.
    I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
    The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
    Apr 18, 2010 | Lowrance iWAY 250C GPS Receiver
    Red cross on sd card on startup
    You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
    Jun 17, 2009 | Tomtom GO 300 GPS Receiver
    Iv got an backup issue with my tomtom one.after backup with microsoft windows xp backup and restor software,i wrongfully formated my tom tom one,now when i restor my backup with windows xp...
    I do some work with TomTom - it's possible that if something interrupted or went wrong during the install, the map could have been deleted. TomTom is aware of the problem and is working to fix it - if you are map-less, call support (866 486 6866) and we can work on getting you a new map.
    Jun 08, 2009 | Tomtom ONE XL GPS
    Deleted memory for garmin c530
    Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
    Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
    Garmin C510 wont install download Europe maps to Unit
    Take a look at the Garmin support page - there is a Question " Why do I get a not enough space message on my Nuvi2xx when trying to update my mapping?"
    It tells you how to remove the unused voice files to free up space.
    I have a Nuvi 255WT and deleting the voice files alone was not enough, so I set about removing a lot of other stuff *** NOTE THAT IF YOU FOLLOW WHAT I DID, DO IT AT YOUR OWN RISK **** it worked for me but there is always the risk of deleting a file that the device needs.
    Also I was stupid and didn't try and save the files to a directory on my MAC before deleting them, from the satnav - worth a try so that if you can do that you have a chance of recovering one that you delete if you want it back.
    First I also removed the un-needed text files - leaving only the 3 British-English files
    Then I removed all of the POI files that were clearly examples/samples
    Then I removed all of the Vehicle files except the one I was using
    Then I removed all of the large ExtData files - now that was the one that caused me the most worry as I wasn't certain what they were there for!
    This gave me a bit over 140Mbyte of free space which was enough to install the 2010 update for all of Europe.
    Now I don't know whether the C510 has the same amount/less/more memory than the 255WT - so this may or may not work for you.
    I didn't have an SD card available, which is why I went this far. I am going to get one and see if I can find out how to load the maps onto that.
    cheers - Jeremy
    Jul 05, 2008 | Garmin StreetPilot c510 Deluxe GPS...
    Lost all maps
    I am very sorry to hear that you had no backup. Theres no way you can recover data once you have deleted it from an sd card. BUT , If you still have the authorisation card ( thats the one that generates the activation code ) then you might be able to copy data from another tomtom card to your card then reactivate it with the authorisation card. GOOD LUCK.
    OTHER TOMTOM USERS NOTE: Backup your SD Card.
    Jun 01, 2008 | Tomtom GO 300 GPS Receiver
    SC card
    I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
    Mar 21, 2007 | Garmin StreetPilot C330 GPS Receiver
    Navigator Evesham Nav-Cam 7000 GPS Receiver Logo
    765 people viewed this question
    Top Navigator GPS Experts
    ray gallant
    johnny rebel
    Michael Grimes
    Michael Grimes
    Are you a Navigator GPS Expert? Answer questions, earn points and help others
