Question about Refrigerators
My ice maker is not making ice, i changed the filter. it isnt getting water. also the water spits a litte when you push the button???
  • 11,896 Answers
It may be the valve not opening or sticking. You can test power to valve with multi-tester
Posted on Aug 01, 2009
ICE MAKER NOT MAKING ICE..WHERE IS RESET BUTTON?
if no ice in tray check for a bad water refill solenoid. If water in tray check for bad heater that does not allow the scooper to push ice from tray into bin. OR
just get a new ice maker on the cheap from ebay
eBayeBay
Sep 22, 2017 | Refrigerators
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
Locate ice maker water level control?
This should be automatic. What is the problem--too litte ice? Do you have a in line water filter out side of unit? Filter in the fridge? Check for dirty filter and you may fix the issue of not enough water getting thru.
Jul 16, 2014 | Samsung RFG297HDRS Stainless Steel
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Change water filter indicator came on so i changed the water filter now the refrigerator won't make any ice, checked the on off button in the ice making unit which is on, what the problem?
This unit has water dispenser and ice maker? If yes, you must get all the air out of your water line, how to do this is keep fill water glasses until you get a good flow of water and no more air, also the water may drip some what so. until all the air is pushed out of the line your ice maker can not make any ice, please let me know what you find. Thanks Rick...
Jul 26, 2011 | Refrigerators
Ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
May 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker not making ice
Make sure that the filter is the right one and that it is pushed in all the way. The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Dec 27, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
