Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
I have a jabra bt 2050 that will not pair it only flashes 3 times any ideas
    President:
  • 1,462 Answers
YOu have to continously hold the power button, till the LED remains stable...
When you see the light stable, you can search for bluetooth dewvice in your mobile and pair ir..
When it as asks for pair code give 0000...
Now you can switch on your blueooth headset normally and now you can connect directly..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Aug 01, 2009
If that does not work, try pressing the center call button while holding the on button waiting for the light to go solid. This was the only way I could get mine to pare.
Posted on Sep 12, 2009
  • neo0 Aug 29, 2011
    Holding the center button until the white light is constantly on is the key. I did this with the code 0000 and that is how I got mine to pair. TY lensvettes!
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Jabra 2050 wont pair with blackberry storm
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Sep 05, 2009 | Jabra Bluetooth Headset with Adjustable...
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Can h700 pair w/multiple devices?
Jabra JX-10 II but i'm not recommend because my friends said that this model not as good as normal JX-10( low volume, low signal, more noise, sth like that)
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
537 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
