Question about Sta Rite 1 1/2 Hp Above Ground Pump Ne642
Pump starts and immediately trips breaker - Sta Rite 1 1/2 Hp Above Ground Pump Ne642
  • nreinhar Aug 01, 2009
    Running on its own circuit, ran fine for 6 years then had this problem. Took it to the pool store today and they replaced it with a new pump, but the same thing is happening again.
    Could the unbelievably wet weather here have caused an electrical problem?
  • 736 Answers
If it buzzes but doesnt actually turn then check the starting capacitor .. when bad, the motor wont know which way to turn and will just buz and get hot until a thermal breaker or external overload breaker trips .. that should happen in about 5 or 10 seconds .. the same thing will happen if the pump is jammed .. make sure it turns freely ..
Posted on Aug 01, 2009
    Scholar:
  • 113 Answers
I would first look at if it is being run on it's own dedicated circuit or if there are other things on with it. Initial start up of a motor or pump in your case there is a surge of power and the amperage will spike up at the start and then come back down after it is running. The pump should have a nameplate on it that says the amperage pull. Make sure you have it running on the correct wire size and breaker. If you have the correct breaker, wire, and it is running on it's own dedicated circuit you may also want to check the connection at the pump or where it is being switched at to make sure that there is not a dead short. Also, is this pump operating at 110v or 220v? Check it out and let me know.
My pool man stated my pump clogged and tripping the breaker. After trouble shooting we find its the motor we tested at different sources and find the same issue the breaker trips. Is the capacitor
Might be but unlikely I would have thought if the rcd is tripping. That would indicate a current leak to ground which is very unlikely to be caused by a dodgy capacitor..
If the mcb is tripping immediately it indicates a large overload such as might be caused by shorted turns in the motor windings (or bad wiring).
The mcb might trip after a short time with a faulty capacitor - the usual sign the capacitor has failed is a humming noise and the motor turning very slowly or not at all, usually the latter.
There are some variables depending whether the capacitor is just a start capacitor or a combination start and run type.
Jun 29, 2016 | Pool & Spa
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
May 16, 2014 | Goodman CLQ36AR49 Air Conditioner
Dryer shuts off immediately after starting and trips breaker'
Seems like you have an electrical short, probably the heat element.
Mar 17, 2014 | Frigidaire Electric Dryer
Microwave tripping breaker
The microwave may be too big for the circuit it's on. The breaker is tripping to protect the circuit. Try to determine how many appliances/lights/etc are running on this circuit. If there are alot of things, you may try turning some of them off when trying the microwave. If not, then you may have an electrical issue in the wiring or the breaker.
NEVER replace a breaker/fuse with anything larger than what's already in there (recommended by code or a manufacturer).
Feb 15, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Porter cable cffn25 won't run. Trips breaker
The little compressors were not built for continuous duty. The pump probably seized, or the motor burned up, or both.
Nov 25, 2013 | Porter Cable Air Tools & Compressors
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
Just installed a new Hayward superpump. Using an intermatic timer (not sure which model, but found something close in a search). Yellow face, A,1,2,3,4 terminals. I wired the new pump like the old pump...
You have 240 volt 30 amp breaker
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
A 1 2 3 4 sounds like 240volt T104 or 240volt T106
These look the same but are two different timers.
The T104 is made for regular on-off operation, while the T106 is made for 2-speed pump.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Now is the pump 240Volts, or 120Volts?
Look at nameplate on motor.
Is the motor single speed or 2-speed?
If pump is 2-speed, then motor will have 3 wires, and nameplate will say Hi and Low.
There is usually a yellow wire with 2-speed pump.
NOW, lets suppose you have 120Volt single speed motor.
You can convert the 240Volt T104 into 120Volt T103 timer by changing the clock motor from WG1573 to WG1570 available at WW Grainger. And then switch white wire inside breaker box to make circuit into 120Volt circuit.
If you have T106 2-speed timer, it can also be converted to 120Volt using same clock motor change-over.
Add a comment and describe your wiring very carefully. Include voltage and exactly which wires are connected, because the description of 'terminal 4 and L4' was too confusing
Aug 25, 2012 | Hardware & Accessories
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
Sta Rite 1 1/2 Hp Above Ground Pump  Ne642 Logo
380 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
