Question about Kingston 2GB Secure Digital Memory Card
My Kingston 2GB SD Card keeps putting my pictures in one folder labeled 206CANON. I have a Canon camera...could the camera be the problem? The picture files are correct, but the card does not create new folders for each set of 100 pictures like it should.
  • abearden23 Aug 01, 2009
    So....what can I do? For example, right now I took four pictures with my camera. When I opened the card on Explorer, it put the pictures into 206CANON, even though the pics are IMG_3336 through IMG_3339. Whether I delete the folder or reformat the sd card, the next batch of pics I take always end up in a new 206CANON folder.
  • 724 Answers
I never herad of a camera function as a catagorical filling cabnet it puts info into its own default folder and increments the picture numbers,
If I am wrong show me the site that has your info?
Posted on Aug 01, 2009
  • tommya300
    tommya300 Aug 02, 2009
    I thought I explained that? Let me see here ... for starters that is the character of the beast it is a default folder that cannon has issued the camera's programming to specify and not deviate from like Kodak canmeras have there own folder issued called Kodak
    So on and so forth depending on the brand ....
    You can change the name of the pictures but it will aways put a number after it in increments.
    Am I making this easier for you to see? Nothing is wrong?
4gb kingston canon ixus 50
The IXUS 50 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 04, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a canon camera powershot SD1200 is digital elph 10 Mega Pixels . Lately when I take pictures the camera works as usual but when I want to review them or to download them to my pc the picture is not...
I have heard of this happening if the card was not formatted on your camera. Be sure you retrieve what you can from the card, then format it in your camera. It may solve your problem. The higher capacity SD mem chips (>2GB) sometimes don't display with some computers. I had to use a separate USB SD reader because the computer would not read the 4GB chip when I put it in the SD slot.
Jun 23, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I have alot of photos in my pc and wanted to put this 2gb card and get them on there
put the microSD into a micro SD adapter and plug the adapter into the SD slot on your PC the folder will open and you can drag photos from your photo folder into the SD folder
Oct 01, 2009 | PNY 2GB microSD Memory Card
Canon SD1200 IS won't save pictures to the memory card.
This Canon uses an SD memory card (previous Canon used CF cards).
The SD memory card has a "slide switch" that locks the card.
Look at the SD memory card and move the switch back and forth, then switch it all the way to the UNLOCK position. Put back in the camera and format the card, then use it.
Since this is a 10Megapixel camera, use at least a 2GB SD memory card. A 2GB SD card will hold 700 pictures, or so, in the best setting.
Hope this helps!
Sep 03, 2009 | Nikon COOLPIX S60 Digital Camera
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
KINGSTON 4GB MEMORY SD CARD
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Jan 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Strange characters in file name
Dear Adriana,
Try downloading your pictures through a USB2 card reader. I have found that some cards are not 100% compatible - a bit like computer memory: Unless the brand is tested and recommended by the manufacturer, you are never really sure until you try it out both in the camera and through computer interfaces. I strongly recommend Kingston Ram. A 2GB SD card is around $18 AUS and has a lifetime warrantee. If it is not compatible, you will get your money back.
Jun 29, 2008 | SanDisk Cameras
Memory card error
try formating.
but u may lose the data
also see that u format through sd utility available on sd.com
if still a issue than get free replacement by kingston as it has 5 yrs warranty
Jun 21, 2008 | Kingston flash memory card - 256 MB -...
Cannot read Kingston 2GB SD card on my computer
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
Regards,
Rakesh Kumar
May 19, 2008 | Kingston 2GB Secure Digital Memory Card
Kingston 2GB Secure Digital Memory Card Logo
49 people viewed this question
Top Kingston Electronics - Others Experts
Jerry Umali
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
