Question about KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit...
Dishwasher not draining
Water standing up in bottom of dishwasher after cleaning not draining dishwasher does not drain completely after cleaning. why?
  • 140 Answers
Re: dishwasher not draining
Look the draining pipe of it, check if there's something blocking it.
Posted on Nov 25, 2007
0 characters
3 Points
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
Ice builds up under the pull out freezer drawer then melts allowing war we to flow onto the floor
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Jul 31, 2011 | Refrigerators
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Inch of water standing in the bottom of the fridge
The defrost drain hole in the freezer is frozen over causing the defrost water to enter the refrigerator through the air duct.
Turn the refrigerator off. Remove the floor panel and the rear panel from inside the freezer compartment.
Break up and remove the ice you see. Use a hair dryer to melt the ice in the drain trough in the rear of the freezer underneath the cooling coils.
You will see a small hole in the rear center of the drain trough. It must be completely defrosted so that water drains through it.
This will take quite some time to do.
You may want to do the above steps and then just leave the refrigerator OFF for several hours to let the drain hole melt by itself.
Dec 14, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
Kitchenaid dishwasher will not drain completely model kuds25shwh1
there is a plastic cover in the back over the drain under the dish tray,, pull out the tray and in th back of the dish washer there you will look down and see a small strainer that is plastic, you will need a 1/4 inch nut driver to remove the cover,, after you remove it there is a couple of pastice peices to take out that are just laying there, remove them and there is a small blade that is there to help cut up food that has been left behind on the dishes,, you can remove this and under it you will find the drain hole,, clean out any debris that is in there, if you have to you might want to take tha bottom cover off the lower front of the dish washer take off the drain hose and flush water thru,, adfter this and then reinstalling everything the way it was, run the dish washer if it still has water sitting in the bottom it is time to get a new pump, it is bad and not pumping,,, you may wish to have an appliance person out to tackle this job,, good luck
Jan 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ----
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
i would check your drain for restrictions under sink. fill with water, and then cancel cycle, did you hear water draining freely??? sounds like a clog
Feb 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit... Logo
174 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
