Question about Dell E173FP 17" LCD Monitor
Tried to fix dell e172fpb
Hi replaced the transistors x4 now the screen comes on for 3 seconds and goes offf again and if iturn the switch off and on again it does the same can anyone help thanks
  • 7 more comments
  • Anonymous Nov 28, 2007
    dell e173fp17 lcd monitor
  • Anonymous Dec 08, 2007
    Same problem here on for 3 sec and goes off again Dell e172FPb
    Please helpppppp
  • wigga Dec 15, 2007
    the transitors are the exact ones but not sure if overheating it only stays on for couple of seconds so not sure thanks
  • BKsproblem Dec 22, 2007
    Same problem with my monitor. Only come on for about three seconds then goes black again.After turning it off then on again it will come on for another 3 seconds or so. Which transisters need to be replaced?
  • Anonymous Dec 29, 2007
    Monitor black
    Flickers briefly when I turn the computer on
  • Becksy Dec 29, 2007
    monitor black - flickers briefly when computer is turned on.
    canned air used with no result
  • Anonymous Feb 16, 2008
    same problem, it does not help by just changing 4 transistors.
  • Anonymous Feb 19, 2008
    The fix...
    The REASON the four (or less) transistors die in the first place, is because the transformers have bad solder joints. Since incomplete voltage is supplied to the transistors, they go bad.
    There are four small transformers near the quad set of transistors. EACH transformer feeds one transistor for the back light circuit. You MUST re-solder ALL transformer joints on the back of the board after you replace transistors. The transformers have a cold joint problem so when the monitor is turned on, the transformers generate heat, and break connection with the PCB. Then the transistors fail.
    If you don't re-solder all the small transformer leads, the transistors WILL FAIL AGAIN. I have fixed many of these, just reheat the joint and add just a TOUCH of solder to it. I mean a touch...don't cross connect the leads with too much solder. Use a fine wire spool of .050 diameter or less.
    This should solve the problem.
    Have fun!
  • Anonymous May 17, 2008
    Found mine in the dumpster, gonna try and fix it up next week
You must re-solder all the transformer joints (four of them next to the transistors) for a fix. There are cold joints on the transformers that break, causing the transistors to fail. Reheat the joints and add just a TOUCH of solder to them on each and every lead. Don't use too much solder, or you'll cross connect the leads.
That'll fix it.
Posted on Feb 19, 2008
  • 238 Answers
Is the transistor the exact match?? checkif it is overheating??
let me know..
Posted on Dec 15, 2007
Back light can be replace even by me. have pulled it apart and replaced with pc cathodes and inverters
Posted on May 23, 2008
A diagram
Posted on Mar 07, 2008
  • 220 Answers
When you replaced the transistors(All 4 C507) I hope you also resoldered the inverter transformers and the FET which drives the transistors.
Posted on Feb 16, 2008
I think one of your back lights has gone, there are two of them, I imagine that when it does come on, it's rather dim.
If so, the monitor is scrap.
Paul Bailey
Posted on Dec 27, 2007
I have a Dell monitor model #1901FP when my computer comes on the monitor comes on as it should. After only a few seconds the monitor goes blank. You can turn the monitor off then back on the monitor...
The solution I am about to describe refers to a backlight problem, which is most common in Dell 15,17 & 19" monitors. The symptoms are as you describe:
  • You power on the monitor, the green on/off switch illuminates and the display works for approx 1-2 seconds and then goes blank.
  • The green on/off switch stays illuminated but the screen remains blank
  • If you shine a torch into the LCD matrix you can see the display being rendered faintly
  • Switching the monitor off and then on again illuminates the display again for 1-2 seconds before going blank again
This is a backlight fault and is most likely to be caused by the failure of two of the four driver transistors used to light the lighting tubes in the LCD Matrix. This fault is easy to repair if you (or a friend) have a soldering iron and a voltmeter.
Inside the monitor there is an inverter board that acts as a power supply for the monitor and the logic necessary to control the backlights (illumination and brightness control). There are four lighting tubes, which are controlled by two lighting circuits (two lighting tubes per circuit). At the heart of the inverter board is a chip that monitors feedback from the two lighting circuits and closes the back-light circuit down if either of the lighting circuits fail, thus any component failure will exhibit the same symptoms.
The transistors which fail most often cost pence to replace (types C5706 or C5707). However, their failure in unlikely to be the cause of the problem. My first crack at fixing this fault, by replacing the transistors, resulted in them failing again within 24/48Hrs. The cause of the problem will be dry solder joints or loose connections on the high-voltage side of the circuit, usually on the backlight transformer in the effected circuit. If you re solder each of the connectors on the transformer you will save the transistors from blowing again - the transformer generates 1,400Volts for the lighting tubes and at this voltage, arcing across the a dry solder joint, will quickly destroy the transistors again.
No soldering iron? - A complete inverter board replacement is also reasonably cheap and easy repair. These are widely available.
Sorry of this is more detail than you expected but it may help others reading this article.
Oct 12, 2010 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
The power light on our model E172FPb Dell monitor is blinking. The screen does not turn on. What could be the problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 19, 2010 | Computers & Internet
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide:
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc:
Jan 30, 2010 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E172FPb screen blinking
If you've tested turning the monitor on without the VGA cable and it's still blinking I'd say there's a problem with one of the capacitors on the power supply card on your screen, when you're able to check it would you mind telling me the brand / reference of it ?
Nov 04, 2008 | Dell E173FP 17" LCD Monitor
Display dies 3 seconds aafter Power on
This is one soution, many more on the net.
You got parts to fix inside the monitor. Inverter problems. The internet is full of this problem. Some say that even if you replace the bad parts, mostly 2sc5707 transistors, you must find out why they are blowing. Many have replaced the parts only to find out that in a couple hours, the parts are bad again. Solutions range from solder joints, transformers, and other transistors.
Good luck, I'm fixing one as soon as the parts arrive.
Aug 17, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor dark but can see image in background
if u have warrenty then immediately contact u r dell service.
he check the problem and replace new one.
i also suffer same problem.
Jul 28, 2008 | Dell E173FP 17" LCD Monitor
Flat Screen trouble
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
Oct 03, 2006 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FP 17" LCD Monitor Logo
3,414 people viewed this question
Alun Cox
