Make sure that the channel (1,2,3) agrees between the sender and base. You might try a different channel due to interference. double check batteries. Then -- remove batteries from remote and base. Then put batteries in remote first (should be next to base) then insert batteries in the base. Be sure channel is in agreement between the units. Sync can take a minute or longer.
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
