Question about Sharper Image 1612911 MP3 Player
Won't load I try to turn it on or charge it & I just get the blank screen with the hour glass. It never changes & never loads..
  • 11,896 Answers
The fimware may need to be upgraded or updated. You will either have to send it in to the company or replace
Posted on Aug 01, 2009
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Zeki 10" tablet won't load
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
Feb 18, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Windows 7 won't load
try going to the bios screen and re installing the windows
Jan 31, 2013 | Acer Aspire One PC Notebook
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
I have a craig mp4 player model CMP616F and i just bought it, charged it, loaded songs and used it 1 time. now when i turn it on a hour glass comes on the screen and blinks and cant do anything else.
i had the same problem with mine searched online and found that someone said to let the battery run completely dead,(turn it on and leave it on til the screen stops blinking) that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
Dec 09, 2009 | Audio Players & Recorders
Hour glass sign on the screen of my MP3. won't go away and MP3 won't start working. The hour glass sign just stays on the screen.
I have a Craig CMP616F MP3 player. In "Set Up", After I set the "online mode" to "Media Device" from "USB Disk", it was working ok until I loaded Apple iTunes. When Apple iTunes attempted to load, it crashed! Flashing start up screen, blue with Hour Glass, then blank out, attempt to restart and the same thing, blue screen with hour glass. There is no known reset proceedure at this time, I started it, let it run and recycle endlessly until the batteries expired. Not recommended, because of battery life, but this did reset this model. Success! A drastic step for the irrecoverable MP3. When I used a standard charger 110v Ac to USB (wall current) it started up, no lost files! Lucky, maybe, I hope this will work for you if you haven't thought of it.
Nov 19, 2009 | Audio Players & Recorders
Hi I cant access my facebook account - I enter my login details & password & the screen looks likes it loading but will then reload to the login page! Help!! I've tried changing my password &...
hi, i'm trying to log in as well, but my page looks like its loading and screen stays blank, if and when it does load it says 2 items left to download and sit there doing nothing
Nov 18, 2009 | Facebook Social Network
Sharper Image 1612911  MP3 Player Logo
180 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
