Question about Ovens
We are unable to light the stove. Each time we
We are unable to light the stove. Each time we light the pilot light and turn the knob to use the oven the pilot light goes out. How can we solve this problem?
  • 744 Answers
Wow! Sounds like an older oven.
Anyway, check the pilot gas jet for carbon or grease build up. Also check the thermocouple for carbon deposits and clean both as needed. Also check your gas regulator if equipped. Finally, make sure the pilot line is tight and not kinked anywhere.
Posted on Aug 01, 2009
    President:
  • 2,559 Answers
Replace the thermocouple
  • 11,896 Answers
After pilot is lit, keep holding down pilot for exactly one minute before turning to on position
If it is still happening, then the spring in knob is faulty and knob is falling down when in on position.
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Light pilot for oven
IF IT HAS A STANDING PIOLOT YOU SHOULD CHECK YOUR BOOK ON HOW TO LIGHT.IF YOU DONT HAVE A BOOK SOME IF THE IMPERIAL STOVES YOU HAVE TO HOLD IN THE TEMPERATURE KNOB IN THEN LIGHT IT. HOLD THE KNOB IN FOR A MINEUTE THEN IT SHOULD STAY ON.REMEMBER GAS IS DANGEROUSE,IF YOU SMELL IT YOU SHOULD STOP AND LET IT AIR OUT.GOOD LUCK BE SAFE
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 21, 2010 | Imperial Ovens
I have a suburban propane oven in my RV. The stove works great but the oven after being on for 5 to 10 minutes starts to puf out. The flames dies then puffs back on. this happens over and over like it is...
My suburban oven pilot comes on but when I release the oven knob to turn on oven, pilot goes out and doesnt lite oven. I replaced safety valve but still the same problem.
Aug 31, 2009 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
230 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
