Question about GoVideo Televison & Video
I have a v2945 model. it has always worked excellent. as of now, I am having trouble with the DVD. When you put in a dvd, it trys to read but it does not. I get a msg hat says No signal. Conect input. Everything is conn ected correctly. The vhs, works fine but the DVD does not. Any ideas? Thanks.
sandrew
  • 2961 Answers
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Posted on Sep 06, 2007
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
I had the same problem! I have the singnal connected to a digital converter box, to the recorder, and then to the tv. the digital channels work ok on the tv from the converter box. However, they do not work on the recorder.
Posted on Jun 03, 2008
RFICKES
  • 51 Answers
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Posted on Jan 04, 2009
  • 189 Answers
SOURCE: dvd player trys to read disc but stops with a HO7
HELLO
This is a motor problem. Here is what to do to put it right.
Open the disc tray and switch off the power, then remove the lid off the player. Locate the disc motor and where the spindle goes through the motor put a little WD40 or light oil (but not too much) or it will get messy.
Turn the disc motor a few times yourself and let the lubricant soak in. Leave it for about 30 minutes then try it again - and it should work.
This works in a number of cases, though I can't guarantee it will work for you. TRY IT! (:-)
Posted on Oct 14, 2009
AJIN G
  • 6694 Answers
SOURCE: My DVD has problem read disc DVD. When I put
hi,
i have got the same complaint some days ago. your players spindle motor is faulty.
its winding have some problem. spindle motor is that one on which the dvd spins. when u insert the dvd it is not rotating at the required rpm. thats why it is not reading. the problem will not be with video cds . because it doesn't required a high rpm. replace the spindle motor. it will not cost a lot. its sure that ur problem will be solved.
if then also the problem remains,
your player's laser pick up unit have some problem with its DVD laser. there are two types of laser in dvd players. one for reading and playing audio cds, mp3 and video cds and the other for reading and playing dvds. in your player dvd laser have problem. dont think that these are two separate unit. the lasers are mounded in the same unit. if any of the laser get damaged you have to replace the whole unit.
if u need any more assistance feel free to contact me through fixya.
bellow is the image of laser pickup mechanism
ok
Posted on Jan 26, 2011
Testimonial: "Hello, Your suggestion was good. Thank you a lot."
Xbox 360 250GB lite, DVD will not read any disks, attempts to read them and then chages to open DVD.
You need to go to best buy or something and get the DVD cleaner, its like a blank CD w tiny little brushes. Run it and run again til it works and Reads could take a few trys. Aslo try to keep your Console away from dusty places
May 05, 2011 | Video Game Consoles & Games
When I put a DVD+RW disk in trys to format the disk then says the disk is protected. If I open and close the door it trys to format the disk again
It may be the brand of disc you are using. Have you tried any other brands? Have you tried DVD-RW? Might make a difference. I'm using DVD-RW and most of them work flawlesly.
Dec 09, 2010 | Sony RDR-GX355
Dvd player trys to read disc but stops with a HO7 message, worked fine last night, but we did put a dvd in to watch but something came on the tv we wanted to watch and didn't turn off dvd
HELLO
Oct 14, 2009 | Panasonic DVD-RV32 DVD Player
I put a DVD R in the computer but it wont let me put anything on it. It is saying that there is no disk inserted
there might problem of your dvd drive not working,, or else can be happen some times that your dvd R is not able to read with your dvd drive..
also..
try cleaning the lens of your dvd drive...
Oct 04, 2009 | Lenovo 3000 V100 Notebook
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Incorrect disk error
Here are a few things you can try.
1. Check the DVD's and make sure that it is not scratched.
2. Check to make sure it accepts that brand of dvd disc.
3. Call technician. Number shoud be on the DVD player or on your manual. How long did you have this player? If you have warranty on it, I would return it if # 1 & 2 is not the problem. It could be a mechanism problem.
Good Luck!
Jan 09, 2009 | Disney DVD2100-P DVD Player/VCR
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Dvd player has trouble reading the discs this dvd writer burns
Go to yahoo and do a search for a firmware update putting in the model number of your recorder or visit manufacturer's website see if they have any firmware update available.
Aug 01, 2006 | Sony DW-G120A DVD RW Dual Layer Burner
Televison & Video Logo
47 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
