Question about HP Officejet Pro L7780 All-In-One InkJet Printer
It isn't showing up on my computer as connected
I have the HP connected to my Mac via a USB port and both are connected to the same wireless network, but the printer isn't showing up as connected to my computer.
  • 724 Answers
If the printer is wireless why dont you just use the share
the dominate will prevail when 2 are trying to do the same.
Posted on Aug 01, 2009
Connection from computer
If the printer is connected via wireless it may not be set up correctly, as a network printer.
Connect it up via a USB cable to make sure it works, then change it to Wireless configuration and re-install it as a network not a USB printer.
Feb 25, 2014 | NetGear Wireless N 300Mbps DSL Gateway
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
I have a very old HP LC3 netserver. It was in my office, and I have moved it to my home. I would like it to communicate with my printer in order to print out documents. Can it be connected directly to my...
Add the printer to the wireless router as another node via DHCP. Then add the printer by the IP address. Your server does not have wireless so it will need to be connected to the router via network cable.
Or, you attach the printer directly to the server via parallel port (RS-232) cable. Or upgrade the server with an USB port, and connect it that way. gl
Mar 23, 2013 | HP NetServer LC3
I have the Zyxel ngg-416n wireless router. when i connect it to my cable system and the the router to my mac, the computer doesn't 'see' the network connection. so i can't load the...
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.
Also check to see if your lan connection isn't disabled on the computer.
For starters
Aug 27, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Can i connect Hp F380 all in one printer to Linksys wrt54g, and i am using macbook, help
From looking at the printer information and the router information, you will probably need additional equipment to make this work.
The printer connects to computers using a USB cable. It does not have a network connection, either wired or wireless built in.
That means you need a print server to connect your printer to the network. Some routers have a print server built in, but the WRT54G isn't one of them.
The print server will have some USB ports to connect the printer to, and connect to the router with a cable, or wirelessly.
HP shows this option: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01428401&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=1128296
If you can find that one, it might work the best. Many print servers have a hard time with all-in-one devices. They are usually able to print just fine, but scanning is troublesome. Make sure to review information about any print server you get, or router with built in print server to make sure it does everything you need.
Considering the price of a print server, it might be a better option to get a new printer that has built in network support. They are more likely to work easily and well. But watch carefully to make sure it can do everything you need (print, scan etc) over the network.
May 04, 2011 | Linksys Wireless-G WRT54G Router
Running os10.3 need to connect a printer.does not have usb ports
You could use a network printer. You counl share a printer on a nother computer and be connected to the inter via Ethernet or Wireless. Or you could go on ebay and buy an usb external card.
May 25, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Want to connect a Mac laptop to a EpsonStylus Photo R340 printer.
Hi
Try connecting the printer to a different usb port if you have extra port and make sure the connection is direct from printer to your mac
Hope this helps
Nov 14, 2008 | Epson Stylus Photo R340 InkJet Printer
D-link router DI524 using next G external wireless modem
You can purchase a usb wireless dongle and attach to the PC. From then onwards you can set up a wireless network without connecting the usb cable for the router. The dongle will enable wireless capabilities on the pc. The only thing left is to have all devices running in the same workgroup.
Mar 09, 2008 | Computers & Internet
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
